M20 MLS head gasket question?
  • FLG
    • Sep 2011
    • 3165
    Originally posted by ForcedFirebird
    Detonate with MLS of o-rings and the head gasket won't be the first thing to go, unfortunately.
    Just what I was gonna say. Blowing a head gasket saved you from destroying a piston. Make sure you get a wideband and a tune before you even drive it.
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • ForcedFirebird
      • Feb 2007
      • 8300
      We used to call the head gasket a boost fuse back in the day lol.
      john@m20guru.com
      Links:
      • yahh
        • Aug 2012
        • 800
        Why are there so many mixed thoughts about o-ringing and MLS Headgaskets?
        s50 86 325e Project
        S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
        Feedback Thread
        • ak-
          • 12422
          LOL.
          There are no mixed thoughts.
          One is cheaper, requires more labor, technically stronger and is an old hot-rod thing.
          Other is more expensive, requires a completely flat head/block, and is also definitely power-capable.
          1991 325iS turbo
          • GUERONASTY
            • Aug 2011
            • 811
            Anyone?
            100 or 200 GRM?
            • Zacm829
              • Jan 2008
              • 1919
              100 GRM is what you want.
              1987 325i-M60b44 swap
              • Overlord475
                • Dec 2010
                • 799
                Originally posted by Zacm829
                I did mine with the block in the car, take your time and the 6th cylinder is a bitch. I had to get creative with the oringing tool handle. The tune is the most important thing you can change or you will be blowing HGs on an oringed block. Gotta pay to play!
                Pics or description of said "creativeness" for the 6th cylinder?
                --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
