Anyone want to share WAR chip Turbo Maps?
  • E Verty
    • Jan 2013
    • 48
    My M20 b25 is currently very, very close to being boosted. I'm getting a chub just thinking about it.
    The guys at miller performance are being very difficult, and wont give me a base tune with the load settings I need. They will only supply turbo loads if you buy the unit/tune from them. Anyone who has a WAR chip knows you cant change the Load/RPM settings for some silly reason.
    Ive got a few different Fuel and Ignition maps made on MS Excel, although I would like to see if anyone has something that works just so I can use the load settings and get some insight from what other people are using.
    Im running a CAT ~270 camshaft, titanium retainers, 24lb injectors, RRFPR and a fancy Water injection/Plasma Spark system that I made for my bachelor thesis.
    I know there are some forums with info/MAP sharing for Miller WAR chip, but there is alot to sort through and no actual .mpc files
    Hopefully you guys can help me out?
    Thanks!
    __________________
  • downforce22
    • Aug 2009
    • 3193
      • 34844
      24# injectors are pretty small for a turbo motor.
      • Cronopoulos
        • Jul 2011
        • 2187
        OP must be tuning on 5psi lol
        Project log -- DIRTY 30
        2.7i * Megasquirt tuned * E85 powered
        • E Verty
          • Jan 2013
          • 48
          I don't need as much fuel because of the plasma circuit. Many people underestimate the power of ignition, water and proper timing.
          I want MAPS!!
