Heat shielding for distributor
  • BMWManiac
    • Dec 2010
    • 1091
    I'm running a top mount turbo on my M20. Unfortunately, we removed the stock mounting bracket for the windshield washer fluid, so right now, I'm trying to figure out either where to relocate the distributor or if there is a heat shield anyone has created or blanket I can use to protect the distributor in the stock location....ideas?
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
  • slow325isedan
    • Mar 2013
    • 113
    I think you mean coil pack? and if so you can just relacate it somewhere on the inner fender. or if you want to leave it im sure you could just fab up some kind of heat shield out of some sheet metal.
    Build Thread
    • BMWManiac
      • Dec 2010
      • 1091
      Yep, I meant the coil pack....just seeing what others might have done....really wish I didnt remove the mount for the washer fluid reservoir...it would have been perfect!
      • chineze
        • 3
        I mounted mine on the valve cover.
        Turbocharged 2.7l M20
        Forged pistons, forged rods, bored block, stock head, KDFI standalone ECU, MSD Ignition setup, T04E turbo running 349 whp
        -Watash Racing Team member-
        • FLG
          • Sep 2011
          • 3165
          Valve cover ara or if your running ms great time to go to wasted spark.
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • Northern
            • 5116
            and a good excuse to go MS if you haven't.
            Originally posted by priapism
            Originally posted by shameson
            • blueapplesoda
              • Dec 2005
              • 1904
              Turbo kit comes with an ms2 unit, so the option to upgrade is there. However, my advice would be to get it running with the stock coil/diz before you upgrade, that way you don't compound problems if they arise.
              As for the heat deflection for the coil, you could buy a "turbo blanket" so you wouldn't have to make heat shields for anything. Works well, ebay has them for cheap. If you don't wanna run a turbo blanket, just get a piece of that adhesive heat reflective foil and put on a bit around the coil.
              • BMWManiac
                • Dec 2010
                • 1091
                I do have a turbo blanket....just thinking if additional heat deflection from the coil is necessary
                • kamotors
                  • Nov 2007
                  • 7102
                  turbo blanket and wrapped downpipe and you wont have issues, things dont get too hot like that. I moved mine here(top left) before I went all out on wasted spark
                  7speedshop.com
                  • wenbeaver89
                    • Jul 2012
                    • 319
                    A pan that you cook with on the stove works great! Modify it to fit the hotside and bam, heat shield/ stainless/shiny!~
