ms pnp gen2
  • mulberryras
    • 40
    ms pnp gen2
    need help for base tune ms pnp gen 2 m20 stock obx adpt holset hx35 42 lb injectors in ny .any help will be good
  • Pootis
    • 636
    Are you running wasted spark or no?
    1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
    COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
    • mulberryras
      • 40
      no wasted spark
      • Pootis
        • 636
        That's unfortunate. I have the exact same setup except I'm running wasted spark
        • einstein57
          • Jun 2007
          • 10780
          Check out e30 tech.
          www.gecoils.com
          • FLG
            • Sep 2011
            • 3165
            Where in ny? I'm running similar setup with 50lb injectors and ebay manifold. Wasted spark but could easily change the tune back to non wasted spark and send it to ya.
            Sent from my Galaxy Nexus using Tapatalk 2
            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
            • mulberryras
              • 40
              i am in yonkers.it would be great if you can send it to me.
              • nomansland92
                • 1657
                Id be interest in a similar tune also, ill be running the same setup in the spring. adapers, 42lb, hx35, and no wasted spark.
                IX being restored here
                Ix turbo build here
                • mulberryras
                  • 40
                  i have not find a tune yet any help
                    • 34844
                    That makes basically no difference except dwell and spark output settings
                    • FLG
                      • Sep 2011
                      • 3165
                      Sorry forgot about this thread. Send me a pm. I'm running ms1 so you might need to just change some of the settings but should get you at least somewhat close.
                      • ColdAsLife
                        • Mar 2013
                        • 142
                        I am running the stock coil right now at about 16lbs on MS2 and e85 with 60lb injectors. I am planning towards 18-20 lbs of boost in the near future if can close the plug gap enough for the stock coil to spark strong enough without blow out.
                        I started out with a base tune that is VERY safe and comprehensive created by the dudes at DIYAutotune. After my fuel got squarred away then i started adding timing carefully.
                        Check it out and let me know if you have any questions. Ultimately if you have issues i can send you my current tune and adjust your REQ_FUEL down roughly 30% to accomodate 91 gas.
                        • nomansland92
                          • 1657
                          Ya I was planning on using that DIYAutotune as a base tune. Should be good to get it started and broke in, until I can find an awd dyno haha.
                          Ix turbo build here
