From knowing nothing to having a Thunderbird supercharger on an m20b27i
  • Ether-D
    • Sep 2011
    • 2838
    #616
    Originally posted by The Dark Side of Will
    Lower compression raises the threshold (in terms of temperature and boost pressre) for detonation at a given fuel octane.
    Preignition and detonation are very different things.
    Lots of info on detonation and pre-ignition and their differences
    And Taco, I was referring to a used m20b27 (not a 2.7i) bottom that would be likely to have less revolutions on it because of lower rev limit (from the factory). I was a bit unclear in my wording.
    Originally posted by Andy.B
    I was born on 3/25…
    • The Dark Side of Will
      • Jun 2010
      • 2796
      #617
      Originally posted by agent
      Maybe for only the short block. Here is the first page of M54B30s on car-part.com sorted by distance:
      OK, TN has surprisingly slim pickin's.
      There's always ebay:
      http://www.ebay.com/itm/BMW-E46-3-Se...6a5b1f&vxp=mtr
      • Ether-D
        • Sep 2011
        • 2838
        #618
        I've got a new plan brewing in the darkest corner of my mind right now. It may involve even more displacement...
        I was born on 3/25…
        • agent
          Vice Grand Pubaa
          • 7960
          #619
          At the risk of being accused of belaboring the point, because I most certainly am, that is only a crankshaft for $425, not
          a whole M54B30 for $500
            • Jun 2010
            • 2796
            #620
            Yes, you are.
            Just because you can't find a smoking deal *right now*, two blocks from where you live with 3 minutes of looking doesn't mean they don't come up.
            Good, quick, cheap; pick any 2, etc. You get a good product on a limited budget by taking your time to find the right deals. I've gotten plenty just by checking back a little later.
            That's a crank for $325 + $100 shipping. Depending on what part of TN you're in, the shipping might not be a thing.
            • agent
              Vice Grand Pubaa
              • 7960
              #621
              If you see a whole M54B30 come up for sale for $500, let me know so I can buy it.
                • Jun 2010
                • 2796
                #622
                Right now there are cores (suitable parts donor for M20 stroker build) as low as $400, but claimed running engines start at $600. Get on your horse for Fontana, CA.
                X5 cores are cheaper, but runners start about $1k
                • Ether-D
                  • Sep 2011
                  • 2838
                  #623
                  …And we're back!
                  So I think I'm thinking about an m30. With an m90. Mmmm? Mmmmm?
                  I was born on 3/25…
                  • Ether-D
                    • Sep 2011
                    • 2838
                    #624
                    3.5l would be right where that Eaton wants to be. I bet it would be so fucking wonderful. Cummy pants.
                    I was born on 3/25…
                      • Jun 2010
                      • 2796
                      #625
                      MOAR TORK!
                      M30 swaps are difficult. It's a big engine and doesn't really fit in the E30 engine bay. Have you been reading up on them? They're also about the heaviest swap you can pick.
                      You'd have to fab a totally new manifold... essentially starting your build over from scratch. You may or may not have room at the front of the engine for enough of an accessory drive to turn the blower.
                      • Ether-D
                        • Sep 2011
                        • 2838
                        #626
                        MOAR TORK!
                        I have read, and I bought the FrankM writeup a year or more before I did the supercharger. I need a project for winter. It may be to make an M30 fit in the spare car, add an M90 and swap the works into my car in the spring. They said I shouldn't try it on the m20…
                        Yeah, I don't care that I'd have to re-do the manifold. That part was a couple weeks of planning and sculpting and was really fun.
                        But I have the FI knowledge in advance this time!
                        I believe I can make the wire harness from the m20 work on the m30 and still use the ms2.
                        I was born on 3/25…
                        • agent
                          Vice Grand Pubaa
                          • 7960
                          #627
                          Originally posted by Ether-D
                          …And we're back!
                          This thread derailment has been brought to you by a grant from The Chubb Group and the letter "R."
                          • Gesture
                            • Mar 2014
                            • 18
                            #628
                            I have an 1986 e28 donor car for sale in Atlanta, Ga(really Marietta). The car was striped my someone else for a chump build but abandoned because of a bad transmission. The engine runs strong and it is has 8:1cr.
                            FIST CAN BE A VERB.
                            • Ether-D
                              • Sep 2011
                              • 2838
                              #629
                              I will keep that in mind Gesture. Thanks.
                              I was born on 3/25…
                              • Q5Quint
                                • Jan 2005
                                • 725
                                #630
                                Here is your engine swap goldmine: http://forums.24hoursoflemons.com/viewforum.php?id=12
                                86 E in georgia: http://forums.24hoursoflemons.com/vi...c.php?id=27118
                                this beauty: http://forums.24hoursoflemons.com/vi...c.php?id=27048
                                here is a guy with some e28 engines: http://forums.24hoursoflemons.com/vi...c.php?id=25898
                                Might be able to talk him down.
