From knowing nothing to having a Thunderbird supercharger on an m20b27i
  • Ether-D
    • Sep 2011
    • 2838
    #646
    Seats polished up nice when I lapped in the new (used but clean) valves.
    Originally posted by Andy.B
    I was born on 3/25…
    • Ether-D
      • Sep 2011
      • 2838
      #647
      And the seat.
      [/url]
      I was born on 3/25…
      • The Dark Side of Will
        • Jun 2010
        • 2796
        #648
        Originally posted by Ether-D
        Here you go.
        Interesting... Higher res version?
        Not sure if it's a trick of the photograph or not, but what's the polished little stripe on the lower right?
        • Ether-D
          • Sep 2011
          • 2838
          #649
          That's the edge of the valve that appears shiny. It's not actually shiny, it's the correct shade of light brown. A bit of an illusion.
          I was born on 3/25…
          • DER E30
            • Sep 2013
            • 2347
            #650
            Sub'd! I like this a LOT!
            Wonder how an M42 would do with a charger...
            -Christian
            • Ether-D
              • Sep 2011
              • 2838
              #651
              It does well, Downing Atlanta used to make one for the m42. They are hard to find now I've heard.
              I was born on 3/25…
                • Jun 2010
                • 2796
                #652
                Just looking for a way to tell if the seat was unevenly worn, pitted or eroded.
                If everything cleaned up from lapping it, you should be good WRT exhaust valves.
                Did you do the intakes as well?
                • Ether-D
                  • Sep 2011
                  • 2838
                  #653
                  I checked the intakes and it looks like two are slightly leaky so I'm gonna do the lot of them as well while it's out and torn down. What does WRT mean?
                  edit: "with respect to", I looked it up on the internets...
                  I was born on 3/25…
                  • Ether-D
                    • Sep 2011
                    • 2838
                    #654
                    The intake valves are lovely. No leaks on the water test after lapping. The exhaust valves on the other hand, are a different story. After not passing the water test, I started to re-lap the exhaust side. On number 2, I noticed that the seat on the head was lapping un evenly. It had a nice thick mating surface on about 7/8 of the seat and did not on the last 1/8.
                    Warped valve seat? I didn't know that was a thing. Is it?
                    I was born on 3/25…
                    • Ether-D
                      • Sep 2011
                      • 2838
                      #655
                      It is a thing, and I've found that if you cut off your valve lapping handle and chuck it up in a drill and then just fuckin go to town on that goddamn warped seat, it'll eventually succumb to your wishes. So that's not leaking anymore. Thankyouverymuch.
                      I was born on 3/25…
                      • Bullhead
                        • Sep 2014
                        • 532
                        #656
                        This thread is freakin killer! Kudos to you sir for being innovative. After all, aren't we all just paying for someone else's elbow grease?
                        sigpic87 325E The Honey Badger
                        • Ether-D
                          • Sep 2011
                          • 2838
                          #657
                          Thanks man. It has been a fricking blast.
                          I should be getting my parts today so I can put this muther-fletcher back together in time to maybe drive it to the Brodeo on thursday.
                          I also think I should go ahead and put the small pulley on the supercharger for to add a few extra boost lbs.
                          I was born on 3/25…
                          • TheTacoMan
                            • Nov 2011
                            • 2308
                            #658
                            Im assuming you have head studs already? A cam would really wake the engine up too.
                            • Ether-D
                              • Sep 2011
                              • 2838
                              #659
                              I don't have studs. I was under the impression I wouldn't need then if I stay under 10lbs boost.
                              I was born on 3/25…
                              • Bullhead
                                • Sep 2014
                                • 532
                                #660
                                Yeah yeah, your gonna try to take your badazz SC to the brodeo and blow off some panties, I hear yah. Make sure you don't blow off an Eaton.
