Cam For turbo Build
  • ser1992
    • Feb 2013
    • 482
    Cam For turbo Build
    Im rebuilding an 885 head, and the time has come to determine what to do with the cam. I can either refurbish my stock one, buy a new stock one, or for about the same price get a 272 from IE.
    does anyone have any experience/insights on what I should do here?
    (my build plans: Revshift full manifold, HX35, IE HD rockers, O-ring block, goetze head gasket, MS2 from whodwho)
    Im looking for about 375-400hp
  • TheTacoMan
    • Nov 2011
    • 2308
    Seen bimmerheads 274 dual pattern first hand, its quite good.
    Also bumping this to see other options.
    • downforce22
      • Aug 2009
      • 3192
      There is the PPF Z45 turbo cam I believe was supposed to be good. Also expensive but I can't find a site for it.
      A couple more cams below from catcams specifically for turbo. I need to research more to determine what cam would be good for the application.
      or
      • TheTacoMan
        • Nov 2011
        • 2308
        That appears to be for the m20b20, here a usa dealer of that stuff. 400$ a cam for the m20b25.
        Duration - Lift: 261°/261° - 11.00mm/11.05mm; 270°/249° - 10.85mm/9.90mm; 279°/279° - 11.05mm/11.05mm; 285°/285° - 11.55mm/11.55mm; 291°/291° - 11.55mm/11.55mm; 292°/270° - 11.55mm/10.85mm; 297°/270° - 11.55mm/10.85mm; 299°/299° - 11.95mm/11.95mm; 302°/302° - 11.90mm/11.90mm; 305°/306° - 12.20mm/12.20mm; 314°/314° - 12.40mm/12.40mm; 322°/322° - 12.40mm/12.40mm; 330°/330° - 12.40mm/12.40mm; 334°/330° - 12.40mm/12.40mm.
        • ColdAsLife
          • Mar 2013
          • 142
          http://server.pure-pf.com/webshop2/i...duct&id_lang=1
          I've read plenty of people in sweden making up to 650 WHP with this cam coupled with proper setup cam timing.
          The next turbo build I do will definitely be utilizing this cam if funds allow for it.
          • wazzu70
            • Jan 2005
            • 1143
            The Z45 cam has been a goto for years. The catcams options are good as well.
            -Nick
            M42 on VEMS
            • dustyperez
              • Feb 2012
              • 390
              Can anyone back up the vac cam?
              • squidmaster
                • Aug 2011
                • 2666
                bimmerheads 280/274 all the way!
                • TheTacoMan
                  • Nov 2011
                  • 2308
                  609$ wow. Ill be going with a 284/280 bimmerheads cam :D.
                  • wazzu70
                    • Jan 2005
                    • 1143
                    Nevermind...the Bimmerheads 272 is from a billet core.
                    -Nick
                    M42 on VEMS
                    • Lurker27
                      • 821
                      Get an Ireland regrind, I love mine and it's under 200. I pretty much kept a 276 profile and gave it more lift, since you're more choked in mass flow with boost.
                      '89 335is +turbo
                      • JCarp90
                        • Feb 2011
                        • 1759
                        I'll be contacting Bimmerheads when I get a cam. For now, I'm too lazy to pull the head.
