MegaSquirt hates my laptop
  • whodwho
    • Jun 2008
    • 1547
    Originally posted by JCarp90
    Any chance you can verify driver version for me? I downloaded the latest from www.prolific.com.
    V. 3.4.62.293. It's the latest as of 10/17/2013
    http://www.prolific.com.tw/US/ShowPr...id=225&pcid=41
    Currently 3.3.7.131
    I had a later one loaded on my laptop before this one because it would BSOD but I could not get the newer one loaded on this one so I am at an older version that came with the adapter but no issues with an older version.
    Phil has changed up TunerStudio serial code and I think it is not so sensitive to versions now. And on the last version is now supporting TCP/IP network adapters, I have a wireless one I set up that you can tether off your phone and seeing if I can use for remote tuning support while you drive :)
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • JCarp90
      • Feb 2011
      • 1759
      Originally posted by whodwho
      Currently 3.3.7.131
      Rub it in. :hitler:
      • JCarp90
        • Feb 2011
        • 1759
        So I got it figured out.
        First off - my laptop sucks and is having issues reading COM ports, so that's part of the reason it didn't work.
        Part 2 - LC1 connects to the megasquirt (obviously) and then of the LC1 controller, are the 2 headphone looking wires running out of it. 1 says IN, one says OUT. From there, there's a wire that connects to serial which is what I was trying to use all the time not knowing that there was a serial port on the side of the MS controller itself. Plugged that in, works great. Fuck my life I'm an idiot.
        Additionally, I found out I have an MS1, not 2 like I was sold. Also the tune is fucked but that's another ball game I won't get into.
        • redsubdivisions
          • Feb 2011
          • 1762
          Part 2 made me lol a bit. Glad you got it figured out. I was starting to get a little spooked because I will be using Win 7 with my MS1.
          1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
          2012 Passat TDI - DD Duty
          2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
          • JCarp90
            • Feb 2011
            • 1759
            I doubt you'll have the issues I did. I ended up having to get a different laptop to connect it though because my main laptop doesn't like MS, but since then I've successfully connected 3 different computers just to test it. Oh, and the default Win7 driver worked fine for me on 3 computers for the Serial to USB driver.
