BMW 327i Boosting Question ...
  • Sindako
    • Nov 2012
    • 116
    Hello Mates .
    See , i need some Answers .
    I have an E30 with a 2.7 bottom end , and a 325i polished head .
    Pro-Formance ECU Euro Racing Chip . Remus Exhaust system , Electric fan swap , etc........
    Now My Question is .
    can i use a turbo kit on my engine bottom end .
    Like Can my Seta Stroker take turbo with no probs .
    Also What Do i need and how many WHP would i get after Boosting My car .
    Kit Needed :
    Turbo Charger , intercooler , pipes , waste gate , BOV , Fuel Pump (I guess), Filter and Housing , manifold .
    What else is missing in my Set up . and how many whp would i be getting ?
    please info on boosting .
    Also .
    A Twin Screw Super Charger ?
    How Many WHP would i get charging my car .
    Like , I need the Charger , Pipes , Harness for a charger switch , Injectors .
    what Else would i need and How Many WHP would i get ?
    In general , how many WHP can it give Charging or Turbo Boosting 327 will give ?
  • kistler#7
    • Jun 2013
    • 186
    Chipped 2.7i is no where near 200 whp. How much boosted power depends on how you build the car
    m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
    http://www.r3vlimited.com/board/showthread.php?t=338818
    • Court M3
      • Jan 2004
      • 6713
      PM kamotors
      Continuous For Sale Thread
      323i s50
      • Liquidity
        • May 2014
        • 395
        An E46 330Ci is barely 200whp. Please don't calculate horsepower like a ricer. And the fuel isn't going to affect your horsepower either, you don't have high enough compression in that motor to make a difference between low and high octane fuel.
        I'm thinking you're not ready for forced induction. Your grasp on all of this is lacking quite badly.
        • sayed ali
          • 762
          Hey man, it's better to read through this forum and e30tech for some period of time then you'll get a clear idea about forced induction, then you're welcome to ask a specific question which is can be answered clearly ..
          M20B28 Turbo
          My Build Thread
          http://www.r3vlimited.com/board/showthread.php?t=255839
          • digger
            • Nov 2005
            • 6178
            how long is a piece of string?
            • Sindako
              • Nov 2012
              • 116
              Read Carefully ,
              Port Polished Head , and An Exhaust system . Running On 98 Octane .
              • Court M3
                • Jan 2004
                • 6713
                Go with this guys advice as well. Read up on boosting and then ask questions. It's all been done before.
                323i s50
                • Liquidity
                  • May 2014
                  • 395
                  Originally posted by Sindako
                  Read Carefully ,
                  Listen carefully - You have a low compression motor and a 2-valve head. You're not making 200whp on that thing. You're lucky if you're making 200bhp. And you don't need 98 octane either. Learn what octane is. Higher octane doesn't make more power unless you have the compression to extract it.
                  • lukey30
                    • May 2014
                    • 39
                    A lot of people boost a 2.7i build, the low compression and long stroke work well with boost.
                    I too am learning/beginning my turbo build, but if you are serious about this, do homework, buy "maximum boost" and join e30tech... No offense to r3v!
                    With a large cam (288 or a dual pattern - I hear good things about mr 325's) and a good tune you may be scraping 200 at the wheels on a good day with your mods... And not the eta bottom end
                    Excuse my redundancy too... Had to put in my .02
                    1989 325i
                    • einstein57
                      • Jun 2007
                      • 10780
                      I know different countries got some really high compression eta's but a SETA would make it not that great. From what i've seen people with cams, headers, and a custom tune make about 170whp. If you had 10:1 CR i could see 200whp easy.
                      But to answer your question use dirty math. At 1bar of boost with a mild tune it should double your current horsepower. Now multiply to how many pounds of boost you plan on running to get your figure. Example, a healthy m20 will make 150whp NA. A turbo setup will give you 300whp at 1 bar, or 225 at 0.5bar
                      www.gecoils.com
