Need help! Turbo wont fit 524td manifold
  • e3irsty
    • Jan 2014
    • 134
    Exhaust manifold mating to turbo is too small for the turbo. My guess is t3 mani and turbo is t4. Its an hx30. Can I just get some kind of adaptor or something?
  • ForcedFirebird
    • Feb 2007
    • 8300
    You should be more worried about the turbo-to-valve cover clearance, but yes, shop on eBay,there's plenty of t3-t4 adapters, but more importantly you will need to make an extension. Sorta like this...
    john@m20guru.com
    Links:
    • e3irsty
      • Jan 2014
      • 134
      Thanks just found an angled t3 to t4. i think this one will do the trick for 38 bucks :D
      • whodwho
        • Jun 2008
        • 1547
        HX30 with a T4 flange??
        I don't know if can even find a HX35 with one, I think they started a T4 flange with a 16cm+ housings and a 16cm was still available in a T3 as well
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • e3irsty
          • Jan 2014
          • 134
          Well I just wasted money.. It's larger than my 524td manifold. I don't know what to do
          • e3irsty
            • Jan 2014
            • 134
            Lines up. But the holes are just a little further apart
            • e3irsty
              • Jan 2014
              • 134
              It is an hx35g sorry about that
              • speedracer 2002
                • Dec 2013
                • 359
                Manifold looks small to me.
                • whodwho
                  • Jun 2008
                  • 1547
                  Here is are T3 & T4 flange dimensions
                  • e3irsty
                    • Jan 2014
                    • 134
                    The 524td manifold matches the t3 atleast distance of the holes does. Its a little smaller exhaust housing and the turbo is more like the t4. Not exact but im thinking it'll work with the adaptor. The top bolt holes are closer to 3.5 in than 3.25 in
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Well....seeing the holes are .100-ish apart using your screwdriver method, those holes would appear to line up.
                      Turbine inlets are fairly standardized hence the above drawing.
                      john@m20guru.com
                      Links:
                      • e3irsty
                        • Jan 2014
                        • 134
                        Lol the screwdriver is just to hold the turbo up for a quick picture. So you could understand what I was saying. I am reassured now. Already bought the adapter and bought kinugawa actuator with .5bar spring so I'm not running 30 psi. Or whatever stock was on the turbo lol. Thanks guys
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          Be careful with that internal gate. It will have severe boost creep, not sure on the minimum with an hx35, but a 38mm gate will bleed off enough exhaust to go 7-9psi safely from personal experience. The internal gate on those is 20 or so mm (off the top of my head).
                          EDIT: Remember in stock config for the hx35, the truck was seeing 40 or so psi in the diesel
                          john@m20guru.com
                          Links:
                          • e3irsty
                            • Jan 2014
                            • 134
                            Im putting a kinugawa actuator on the turbo with .5 bars to start with and porting the turbo same way as described in this link. Hopefully I'll be all set with the turbo once that is done. Also there are 5 holes for coolant and oil. Why is there 5. I know the 2 oil holes and two coolant ones next to eachother. Then there are two more holes for coolant i believe. 1 is already blocked off. Can anyone explain. Thank you. Heres the link for turbo porting http://www.bellengineering.net/artic...7fvsdib385bpu3
