E85
  • DirtyMaxTJ
    • Jun 2013
    • 146
    E85
    Im trying to decide whether I want to run e85 or run 91 + meth. I would like to hear people's opinions on how they like their fuel setups and why they chose what they did.
  • cleanasse30
    • Jan 2014
    • 436
    If you can easily get E85 in your area and your car isn't your daily there is really no reason NOT to run E85.
    The only reason it isn't used more imo is because of availability and cost/mile. E85 has a lower energy density so you need more fuel and larger injectors, but it has a much higher octane than standard gasoline so you can throw more timing at it without problem.
    TL;DR: if you can easily find it E85 will give you more power, but you will be at the pump more frequently
    2.7i Stroker Turbo Build Thread
    90 325i | 95 Miata
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      E85 if you can get it. My buddy's 1000hp Evo thrives off the stuff just make sure you never leave home with out an extra couple gallons in a spare tank I'm not kidding either
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • DirtyMaxTJ
        • Jun 2013
        • 146
        E85 is at nearly every gas station in my area and this is just my weekend/fun car. The only reason I'm skeptical is because I already have 60# injectors and to my understanding, with e85, 30% more fuel is required so I think I would need bigger injectors for my 400whp goals. Ah screw it, I'll do the math and if I need bigger injectors, I'll get them. Plus, the major tuner in my area loves e85 so if I need help tuning, I'll have it. Thanks guys!
        • IronFreak
          • Dec 2012
          • 3702
          Calculator for the best injectors ever made
          I'm going to bet, not knowing your setup you'll need id850s minimum. I'm setting up to run e85 as well. my setup will require id1000s to run enough fuel on my setup. Another thing to note, you need to look at the rest of your fuel system. e85 compatible fuel pumps, lines etc. WaLbro makes a 485 model that e85 compatible. Good option of you're still running a stock tank, you can buy a full installation kit and pump of amazon for about $180.
          E85 is a different animal, you need to analyze the switch as a whole and not just injectors.
          Instagram @rebellionforge
          • cleanasse30
            • Jan 2014
            • 436
            ^^ +1 ID1000's are the bees knees. Injector Dynamics FTW
            90 325i | 95 Miata
            • hyperE30
              • Sep 2009
              • 2202
              I run e85, 100lbs ID's, stock lines and stock tank, stock fuel rail and stock fpr. No problems what so ever. Cold weather no problem either
              HyperWerkz
              89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
              " enjoy the show "
              • Northern
                I like cupcakes & sh!tboxes
                • 5284
                I feel like Siemens Deka 80lb/HR would get you pretty far for much less wallet rapeage
                Originally posted by priapism
                Originally posted by shameson
                • IronFreak
                  • Dec 2012
                  • 3702
                  there is a lot of info being left on the table to properly determine what size injectors he should be using.
                  • Meta
                    • Sep 2015
                    • 49
                    bump...
                    more info on injectors plz!
                    what if i ran the m90 s/c?
                    is it the same for 2XXhp as 4XXhp builds?
                    • VRMNSTR
                      • Jan 2015
                      • 7
                      hypere30- what did you do about emissions? ive seen your beast at Lafayette CC a few times. I wanna ride!
                      • nomansland92
                        • 1657
                        I'm actually in the same situation, either buying bigger injectors and pump of just using water/meth. Around my area there only one gas station that had e85 but I usually don't dd the car. What's the down fall of water/meth?
                        IX being restored here
                        Ix turbo build here
