need help with turbo build
  • zaxxe30
    • Sep 2014
    • 103
    hello I have a 1987 325ic I would like to turbo. I need some help on what I will need.
    so far i made a list and what like to know what else i need so i have:
    ms pnp ecu
    intercooler
    turbo manifold
    not sure what turbo to get for over 400hp
    arp headstuds
    bov
    oil return and feed lines
    headgasket
    performance coil pack
    performance pluugs and wires
    fuel pump
    electric fan
    injectors
    so i would like to know what im missing
    thank you
    '87 325ic
    '91 318is (first car) sold
    '99 m3 (sold)
    '84 porsche 944 (sold)
    '01 subaru legacy wagon
  • ak-
    • 12422
    I don't know man. Rather than making a list, try to research turbo systems and understand how they are put together and work. Find out what part does what and why. Then, choose what suits your needs. Research faults and issues turboing m20's.
    Find out what you might want to do as preventative maint. for 400hp. I see nothing in your list that concerns the head or block. You're not going to need a list after doing all that - you'll just know. E30tech has a lot of good info. Good luck.
    One thing you do need though is money, patience, and time.
    1991 325iS turbo
    • zaxxe30
      • Sep 2014
      • 103
      Ive got the money the time and the patience. Ive been reading turbo builds for the past 6 months now and this is what ive seen on all. I would like to just know what else I would be missing
      '87 325ic
      '99 m3 (sold)
      • downforce22
        • Aug 2009
        • 3192
        ms pnp ecu
        intercooler
        turbo manifold
        arp headstuds
        bov
        headgasket
        fuel pump
        electric fan
        injectors
        thank you
        IC piping and couplers
        intake boot
        wastegate
        wideband oxygen sensor
        gauges and senders
        exhaust/downpipe
        oil catch can/ ccv
        possible oil filter relocation/ oil feed adapter plate
        • zaxxe30
          • Sep 2014
          • 103
          intake boot
          wastegate
          gauges and senders
          exhaust/downpipe
          oil catch can/ ccv
          where can I get the intake boot from?
          '87 325ic
          '99 m3 (sold)
          • downforce22
            • Aug 2009
            • 3192
            This website is for sale! millerperformancecars.com is your first and best source for information about millerperformancecars. Here you will also find topics relating to issues of general interest. We hope you find what you are looking for!
            Check this out...
            • zaxxe30
              • Sep 2014
              • 103
              Thank you. I have also found this turbo kit that gets about 210hp without upgrading the fueling system or the engine management. What I would like to know is if a wideband sensor is needed and if you can find me a link on how to install it because I dont know how to the turbo kit is here:
              '87 325ic
              '99 m3 (sold)
              • downforce22
                • Aug 2009
                • 3192
                http://www.ebay.com/itm/CXRacing-84-...14aba8&vxp=mtr
                Some people like them, some don't. I have that exhaust manifold and it doesn't fit the head. The holes don't line up so they need to be drilled larger and the manifold design is terrible. I don't plan to use it.
                Sure it will work after much modification, but do you really want to spend 1300 on a pile of ebay parts that might work OK, or a bit more on something that is meant for the car?
                They also dont show air fuel ratios on that e30 which were probably lean on that engine, look at it blow blue smoke @34 seconds on the dyno... thats reassuring
                You need to do some research. This has been covered many times before :hitler:
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5202
                  You say this:
                  Then you turn around and post this:
                  So which is it? You've read enough threads to know that everyone upgrades their injectors and often their fuel pump, and runs aftermarket management from the start or after learning their own lessons about rrfprs/"Turbo" chips.
                  But then you say "Look at this great ebay kit that says I don't need any of that stuff that everyone else did."
                  Originally posted by priapism
                  Originally posted by shameson
                  • zaxxe30
                    • Sep 2014
                    • 103
                    Basically I want to know if I can turbo with out upgrading ECU I can update fuel system of needed but I wanna know if I can use the the afm and stock ECU and without using wideband
                    '87 325ic
                    '99 m3 (sold)
                    • zaxxe30
                      • Sep 2014
                      • 103
                      http://www.e30tech.com/forum/showthread.php?t=88791
                      thanks i really appreciate all this info you have provided me with
                      '87 325ic
                      '99 m3 (sold)
                      • gotaloveRWD
                        • Jul 2011
                        • 708
                        Yes a lot of things will work but how good and for how long
                        Spend 3-4x as much money and you will be 100x happier
                        It's not cheap you gotta pay to play
                        Just my thoughts
                        IG- nv_e30
