Turbo m20 fuel setup
  • dirtyEthirtyIX
    • Apr 2017
    • 123
    Turbo m20 guys, what is your fuel setup? How do you like it? My setup is stock late model pump, aem 400lph inline pump, aeromotive 30-100psi afpr. I haven't finished my build and any input or advice is welcome and appreciated.
  • E30-Ellerman
    • Oct 2015
    • 212
    Mines a stock early model with 300lph inline pump, new OEM FPR, 36lb injectors and the megasquirt pnp from diyautotune. Mines low boost at 11 psi but same as my buddies 350-400whp car and runs perfect without issues. 400lph is a lot of overkill I’m thinking.
    2016 F-150
    1987 Royalblau 325es B25 turbocharged
    Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594
    • dirtyEthirtyIX
      • Apr 2017
      • 123
      My brother had it laying around from different project. I'm also running 60lb injectors and ms2 from whodwho, I went with the kamotors canyon crusher turbo kit and stroked to 2.8l
      • digger
        • Nov 2005
        • 6216
        What are people finding asthe limit for the intake late model pump ?
        • E30-Ellerman
          • Oct 2015
          • 212
          I think people generally just automatically toss in a Walboro 255lph or a Bosch pump.. pretty cheap and leaning out due to a insufficient fuel pump is never good.
          I ran 11psi on my early model dual pump setup for like 300 miles without issue... Think the late model early taps out around 7-8 psi?
          2016 F-150
          • e30davie
            • Apr 2016
            • 1788
            Technically the way to do it is to work out how much fuel you actually need using this calculator,
            Then see how your pump compares. Id say you want 50% headroom.
            It is also possible to have too much flow, and all you end up doing is pumping your fuel around and around your engine bay heating it up. And then can get vapor lock....and you get a noisy fuel pump.
            • digger
              • Nov 2005
              • 6216
              i'm wanting to run a standard pump on my NA stroker. i'm expecting a decent bump in power from what i have now to end up somewhere at most double the factory b25 power level so just wondering if im going to get issues.
              • Tonybeemer
                • Jun 2014
                • 59
                255 intank and Bosch 044 in-line ., stock fpr, 60 lbs injectors ,5/16 hard lines feed and return, 16lbs of boost 400hp haven’t had issues
                • nomansland92
                  • 1657
                  Currently ruining a walbro 450 in tank with id1000 and stock lines. Soon switching to 8an feed and 6an return and aftermarket fpr and id1300 for e85. Hopfully good to 600 wheel with that setup.
                  Sent from my SM-G892A using Tapatalk
                  IX being restored here
                  Ix turbo build here
