M20 turbo wasted spark melting spark plugs
  • syn52k
    • Feb 2017
    • 9
    Hey guys I'm new to megasquirt I have my car running at about 10psi with wasted spark I keep melting spark plugs I'm assuming my timing advanced is to high if anyone can help me out tuning my car or tell me what to change in timing I'd really appreciate it
  • varg
    Florida Turbo Man
    • May 2014
    • 3430
    Are your plugs in the stock heat range?
    IG @turbovarg
    '91 318is, M20 turbo
    • syn52k
      • Feb 2017
      • 9
      Bpr7es at gap is 28 sorry should of mentioned that
      • NEOe30
        • Jun 2016
        • 415
        Make sure your ignition settings are set correctly for your coil pack setup. Dwell times.
        • NEOe30
          • Jun 2016
          • 415
          also why running wasted spark?
          • syn52k
            • Feb 2017
            • 9
            I'm running gm coils can you give me alittle advice the only thing I changed in megasquirt for ignition was changed to water spark I know theres alot more than just that if i keep driving it like that I'm afraid I'll melt a piston
            • NEOe30
              • Jun 2016
              • 415
              What megasquirt are you running? How many ignition drivers do you have?
              • syn52k
                • Feb 2017
                • 9
                Ms2 pnp and I have no idea I'm just learning megasquirt
                • NEOe30
                  • Jun 2016
                  • 415
                  I can’t tell if you have 3 or 6. Are you sure you can’t run Coil on Plug ignition instead of wasted spark?
                  • NEOe30
                    • Jun 2016
                    • 415
                    That should save you a lot of heat. Either way you should look up the proper dwell settings for the GM coils you are running to make sure you’re not running them too hot
                    • syn52k
                      • Feb 2017
                      • 9
                      MSD-8224 3 of them
                      • NEOe30
                        • Jun 2016
                        • 415
                        MSD-8224 3 of them
                        Okay so you’re running wasted Coil On Plug?
                        Again, make sure you have the correct spark duration and dwell settings
                        • LowR3V'in
                          • 4209
                          melting spark plugs? take a picture.
                          Those are just GM replacement coil packs.
                          did you mod the gm base or use the msd one?
                          post n tune and log pls.
                          look at this maybe u can find on error from brads old write up.
                          also, what plugs do you have pls say they are colder.
