Bosch 42lb Green injectors maxing out around ~10psi?
  • Fraser
    • 201
    Does this sound right? Stock m20, HX35. MS logs are showing >100% duty cycle. I know MS calculates DC off of a variety of factors and isn't necessary accurate. I was always under the impression that those injectors are capable of quite a lot more than that...
    325iX Turdbo Rally/Hillclimb/Beater
  • Jaxx_
    • Dec 2009
    • 1880
    Gasoline, I assume? When you "run out" of duty cycle, do your AFRs start climbing? Is your fuel pressure manifold referenced? As I'm sure you know, it's impossible to have more than 100% duty cycle.
    10psi doesn't mean much, per se. The injectors you have should get you to around 325whp, I would expect. How fast does the car feel?
    • Fraser
      • 201
      Yes, Gasoline. The AFR's are where they should be, even when the indicated DCs are through the roof. The fuel system is bone stock m20 stuff.
      The car is pretty fast, butt dyno says 280hp or so, maybe a little more? But who knows...
      • Jaxx_
        • Dec 2009
        • 1880
        post your msq and a log
          • 34844
          if your injector constants are not right, the duty cycle will be wrong. If you're seeing duty cycle over 100% then you need to readjust the constants. This will also likely require VE table adjustments.
          • Fraser
            • 201
            Forgive my ignorance, but specifically what settings need to be looked at on the constants page?
            I'll post an MSQ and log later this afternoon, I need to grab my computer from the shop to look into this further. Thanks!
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              check your fuel pressure too, maybe something pump or regulator related
              Originally posted by priapism
              Originally posted by shameson
              • LowR3V'in
                • 4209
                if it reads 100dc+ yet it still responds to increasing ve
                then it is not at 100.
                idk the limits of the stock pump or the draw but i do know the stock wiring sucks
                and if u wire the pump from the batt. on a relay it will get you where you need to be.
                if not for this then for future pump needs. stock wiring is shit.
                my 255 was going lean and wiring it this way gave me that extra needed fuel
                10psi on stock hx35 setup i don't think you are maxing them out.
                i am rusty on MS settings but your dead time and fuel requirements are not right.
                • Fraser
                  • 201
                  Thanks for the info- that's not the first time I've heard it's wise to rewire the pump with it's own circuit and relay.
                  Here is a link to the current tune and a couple logs- one is ~12 psi and is busting 100 DC, another is back down to 10psi and still hitting near 90, which I do not believe to be correct. Thanks to whoever is interested in looking at them...
                  • LowR3V'in
                    • 4209
                    9.8arf @ 11psi it's drowning.
                    Even your targets are 11.5afr that is way too rich for the boost.
                    try 12.5 afr.
                    • Fraser
                      • 201
                      try 12.5 afr.
                      Geez, no kidding. I've been running around at 6-7 psi for so long while I was troubleshooting a spark miss I guess I never noticed those higher boost squares running so rich. Obviously that would explain the duty cycles being so high in those same areas also.
                      I'll work on those tables a bunch over the next few days and see what it looks like.
                      Thanks for your help!
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        Shoot me a datalog with the current .msq, last one said 65% if memory serves me correctly. I owe ya a beer/soda. :p
                        john@m20guru.com
                        Links:
                        • Fraser
                          • 201
                          Will do- I love beer! I think my current overfueling issues had to do with hitting KPA values that hadn't been hit before and were thus tuned conservatively (really) rich...
                          I'll send over the most recent log and MSQ and see what you think... I'd like to run 12-14psi regularly which looks like shouldn't be a problem with the current hardware once I get the tune a little more dialed. Other than my stock clutch which is starting to slip like a bastard and needs to be replaced ASAP.
                          Thanks guys!
                          • tschultz
                            • Jun 2013
                            • 332
                            I was going to say.... our altitude and 10psi shouldn't be pushing those injectors! I downsized to 30#'s on my M30 to try and have excellent performance throughout operation for my car up to 160kpa.
                            http://www.Drive4Corners.com
                            • Fraser
                              • 201
                              Wow, how much power are you running on the 30#s? I would consider going to smaller injectors at some point to get some of my cold start issues cleared up...
