Goals and reality need some help here
  • Joegreen02
    • Dec 2018
    • 80
    OK I'm running ms2 23.5 lb injectors basically stock ignition.
    Maf delete
    Schrick 284 cam
    I have a turbo manifold on the way and intend to run maybe an hx35 turbo intercooled
    Am I gonna be able to put 250 to the wheels with this recipe?
    Of not what am I missing?
  • varg
    Florida Turbo Man
    • May 2014
    • 3414
    Needs bigger injectors. HX35 is overkill for so little power, will lag like heck. Get a smaller or more modern turbo. Pointless to use such a big turbo unless you're going for big power and don't mind the lag. For 250whp go with a T3 super 60 or something, that way you get good boost response.
    IG @turbovarg
    '91 318is, M20 turbo
    • Joegreen02
      • Dec 2018
      • 80
      Thanks for the feed back! I definitely don't want Abby more lag than is necessary. I'll be looking into the super 60.
      • cream_e30
        • Oct 2018
        • 30
        The Ford 40# injectors are perfect for your application.
        Like has been said, hx35 is a bad turbo for 250... I like Garrett so would use a GT2860rs for your goal.
        Sent from my SM-G960W using Tapatalk
        • Joegreen02
          • Dec 2018
          • 80
          I'll be looking into the Garrett as well and the 40lb injectors! Thank you!
          • Joegreen02
            • Dec 2018
            • 80
            OK so I wound up with a precision 3231e turbo
