Gas mileage with m20 turbo?
  • bo0stedc2
    • Oct 2006
    • 220
    I was just wondering what kind of gas mileage people are getting with m20 turbo'd cars. I am planning on going turbo and i just wanted to see how the gas would be. Please post what setup you are running. Thanks!
  • Erick
    Official R3V Drifter
    • 11169
    If you drive it like a responsible human being, your gas consumption would be no greater than stock.
    Gas consumption goes down as the boost needle goes to the right of zero.
    I get 27mpg highway with my 2.93 rear end.
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
    • bo0stedc2
      • Oct 2006
      • 220
      What motor setup are you running? Stock or semi-built motor? How much boost to set for daily driving? Thanks!
      • sticksdaman
        • Apr 2005
        • 2987
        also note that his car is considerably lighter than stock
        Originally posted by ebelements
        Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
        • Shoomakan
          • Sep 2007
          • 123
          Well, when my M30 is floored is does about 40km/tank. After I threw the turbo in, it went down to around 25 km/tank. Keep in mind this is when fully racing, not just speeding around. WOT all the time...
          I usually get an average of 120/tank mixed.
          A decent M20 should be in the whereabouts of 170km/tank if driven nicely.
          • moatilliatta
            • 6152
            my Buddie got 21mpg and hes allways in it. also has a 2.93 rear end. I get 21 mpg in my ix...
            @Zakspeed_US
            • Erick
              • 11169
              With a turbo setup (manifold + turbo + intercooler + other things stock cars dont have), a 6 point roll cage that has to be freight shipped due to size/weight, I would hardly consider the little interior that I have removed to be such a huge weight loss.
              My car probably weighs 2600-2700lbs wet.
              Feedback Thread
              • naika
                • 466
                I am curious to know if a stock M20 could take a turbo set up? and if so, what boost to use for daily driving?
                I have a 3.97 LSD (or something like that ;-), is it necessary to replace it with a lower ratio, 2.93 for example?
                Sorry for the stupid questions but I am starting to look into boosting my car.
                Thanks
                344is! Obd1 conversion
                • Erick
                  • 11169
                  My stock M20 has been taking 2 years worth of monthly drift events, including drive to and from those events. Still hasn't skipped a beat.
                  It all depends on how much power you're pushing and how much you have invested in reliability.
                  As the saying goes: "Cheap, Fast, Reliable. Pick two."
                  Feedback Thread
                  • backtrail69
                    • Jul 2005
                    • 4471
                    I am running a built 2.8 with a HX35, MSnS, 3.73 rear and I am still getting over 20mpg even in the tuning stages. I could probably get 230-240 to a tank easy. On my old 2.5 with everything dialed in I got 27mpg freeway once. (Still with the 3.73) Should only go up with lower gearing.
                    PS My 200k mile m20 lasted through 2 years of abuse before I killed it. Still drove into the garage for the motor swap. :)
                    :: PNW Crew ::
                    '87 325 4dr, '74 2002
                    • sticksdaman
                      • Apr 2005
                      • 2987
                      wait... ok i got 321 to the tank all highway which is like 25ish a gallon
                      how are you figuring 170k a tank?
                        • 34844
                        170km on one tank is horrible. that's like 7mpg! if your car is getting that poor of mileage you either have it tuned pig rich or you're WOT 100% of the time. even in my cars worst stages of tune I never got less than 12-14..
                        • andrewintraining
                          • Jan 2008
                          • 78
                          When you guys say 2.8, did you guys bore your original 2.5's?
                          Looking for an e30.....
                            • 34844
                            bore and stroke, generally. you can't bore all the way to 2.8
