do you have to run MS or is there a way to get a turbo m20 to run well without MS.
turbo engine management
RRFPR and a chip. It will run of the AFM but dont expect it to make much power or last for long. My 2cents.** Lot's of M20 turbo parts for sale.**
Turn key track car.
http://www.r3vlimited.com/board/showthread.php?t=222066 -
by the time you buy a rrfpr and a chip, you've spent enough to buy megasquirt, but you cant tune anything... just use megasquirtComment
Are there any aftermarket ECUs that are commonly used in the japanese car market that we can use?
Mainly because I would be able to get a great deal on tuning if it was something they were familiar with. Perhaps AEM EMS?Comment
I dont have no idea of how to wire ms I have read the sight 100 times and nothingBig Mike Hunter
BMW Enthusiast
Not2Close Motorsports
Like us on Facebook
https://www.facebook.com/pages/Not2C...35086986557277Comment
If you don't have any idea how to wire megasquirt, you are in luck, as I sell a plug and play megasquirt setup where all the wiring is done, http://www.r3vlimited.com/board/show...ght=megasquirt85 325e 2.7 ITB'd stroker
You can use what ever you want. MS is difficult cause you have to mod the board to get it to work for your car. Buying a better sealed ecu is way sweeter but you still have to go through wiring it to the car.
The FMU (rrfpr) and slightly bigger injectors has been a proven method for YEARS. The only down fall is its only safe until about 8 or 9 psi. The reason you can get away with it on your m20 is you can "tune" the AFM enough to get the car to run well on larger injectors (i hear 30lb/hr is the limit) before boost and then the FMU takes car of the rest.-ChrisComment
When I was into hondas I had turbo'd a single cam d series using an fmu. Everyone told me not to do it because it is unreliable. I had that set up on 13 pounds for over a year, and I drove the hell out of the car, before a motor mount broke and I dropped the engine while doing 60mph. You can make it reliable by taking out a little timing and upping the fuel pressure a little. They guys that told me not to do it, they all blew up their set ups. I'll probably just go fmu and a chip on mine, since I am not looking for huge power.Comment
not everyone is not looking for big power.
but it eventually finds you and you can't stop wanting more.......Comment
my car isn't being built for speed. Plus I am not hp hungry. I am just looking for that little extra kick to get the car sideways ant 45 mph. Now when I eventually swap to something newer/better Then I'll probably get m/s or something. I don't care to much about the m20Comment
I am runnig an smal garret T3
I Have an old ´86 motor with motronic 1.0 and smt6, 315cc injetors, RRFPR, and wideband
Not an expensive way
still have the afm runnig 13psi ( full bosst inn 2 gear around 2800 rpm)325i Turbo 1986 4door
335i M-tech II 1990
KFX 450r ATVComment
R.I.P 07/01/09 - 04/23/10 :(
