Megasquirt is worth it. Just keep reading and researching and you'll be allright. If you want to build it yourself DIYautotune.com sells an adapter board that plugs straight into your m20's stock engine harness.
turbo engine management
tcd sells a chip and you cna also find ebay knock off ones. they say there for up to 15psi.... all they do is retard timing after 3000rpm... there are plenty of guys over on e30tech runnin the chip adn rrfpr, with bigger injectors... one guy i talked a bit isnt even running the chip jsut 30lbs injectors and the fmu. he runs 10 psi, and makes over 300 whp. with the chip for 15 psi you can safely run more boost and make more power.
he has a stock eta bottom end with i top, i dont recall what size exhaust he has. his turbo is a garret .60 trim
factory ecu is best !
Originally posted by slowpoke6 View Postdo you have to run MS or is there a way to get a turbo m20 to run well without MS.
Good luckGrease Monkey's Uncle
