Why not boost the ETA?
  • ForcedFirebird
    • Feb 2007
    • 8300
    Form what I understand the ETA has a 9:1 compression, correct?
    I boosted a 9.1:1 GM V6 last winter and is running 12's in an auto FWD car. My Firebird has 11.5:1 and am twin charging it. I will see the same effective compression at 6psi as a stock 9.6:1 V6 with 10psi (which is common place in my community).
    What people don't realize is that when you apply more air to an engine (boost), you are raising the effective compression (compression the engine sees while running).
    So, if we have a 9:1SCR and add, let's say, 6psi over atmosphere, it translates to about 12.7:1 effective compression. You are still pounding the same ammount of air in that cylinder as a 8.5:1 motor at 7.5psi - although I am simplifying this, you get the point; cam, porting, chamber shape can all have effet on the outcome.
    Let's discuss,
    -John
    john@m20guru.com
    Links:
  • Need4Speed
    • Jul 2008
    • 95
    Because they will blow up?
    • backtrail69
      • Jul 2005
      • 4471
      No... The reason its stupid to boost a eta engine is revs... HP is calculated (TQ x RPM)/5252 and if you arent spinning very many RPMs you aren't going to be making much power... also the head doesnt flow very well compared to an i...
      :: PNW Crew ::
      '87 325 4dr, '74 2002
      • ForcedFirebird
        • Feb 2007
        • 8300
        Then how do you explain the turbo diesels that won't turn as many RPM's as the 2.7 even?
        What I want to know, is why is 9:1 compression too high?
        Here's a vid for 'yas. This is a 9.1:1 at 15psi (the car I built for a customer last Dec)...
        A friend came down from central Florida and I made the kit from scratch for him in about 48hrs, the only thing that was made before hand was the headers up to the collectors (I made them on an engine stand). In that 48 hrs, found time to do the side exit exhaust, and make the small items on my CNC machines, like flanges etc.
        john@m20guru.com
        Links:
        • ban1
          • Nov 2007
          • 235
          Just boost it and if you dont like it throw an i head on it ,but you could just go ahead and put on the i head.(FLOWS BETTER)
          • napabavarian
            • Jun 2008
            • 834
            Do it to it it'll be a torque monster if it is done right.
            This place is like catholic school, 2/3 of the students smoke weed on a daily basis, but the faculty seems to convince the outside world that drugs are just in the other schools, the resident pot dealer thinks he's cool because he has the originality to call anyone he doesn't like a homosexual, and most of the little children follow him like sheep, then there's the few with brains, you hardly ever hear from them, perhaps don't even know they exist, but they get all the sh!t done.
            • ForcedFirebird
              • Feb 2007
              • 8300
              Yes, I know about the i heads ;)
              I'm doing the same thing on my v6 motor. Using a '94 block and '04 heads in the Bird. The old iron heads flow ~127cfm intake and the aluminum '04 heads are ~225cfm.
              My question still remains:
              Why is the compression on an eta too much?
              john@m20guru.com
              Links:
              • ForcedFirebird
                • Feb 2007
                • 8300
                Oh, I have a few plans for the eta :D
                I'm swapping in a GM ECM (same ECM that controls a Syclone/Typhoon ;)), then an i head swap, then undecided if I want to see big N/A numbers, or boost it.
                john@m20guru.com
                Links:
                • backtrail69
                  • Jul 2005
                  • 4471
                  The compression is not the problem its the shit head on it..
                  Here is my 2.8 (2.7 crank 1mm overbore and i head (stock with 273 cam)) at only 10 psi... I suggest you invest in i head swap
                  :: PNW Crew ::
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Yes, I understand the flow difference between the i and e heads.
                    BUT the same goes for my other car (as explained above), yet the iron heads with boost will still do quite well (~12-13sec 1/4's).
                    When you have a lesser flowing head and you apply boost, you have lesser issues with port volume, velocity, and definatly making power, than you would talking N/A.
                    Does anybody here (or can link me to threads with) flow data on the various stock heads? Perhaps someone maybe even went as far as testing with/without manifolds as well?
                    EDIT: I posted before you pic insert of the dyno graph ;)
                    Anybody have numbers on the e head and boost?
                    john@m20guru.com
                    Links:
                    • ethree
                      • Aug 2007
                      • 1216
                      Don't weak single valve springs like those found in the eta head like to allow valves to float and fuck shit up?
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        Only if you over-rev ;)
                        john@m20guru.com
                        Links:
                        • ethree
                          • Aug 2007
                          • 1216
                          Or have a spike in boost ;)
                          • Jordan325iC
                            • Aug 2005
                            • 1697
                            I have never heard anybody argue against the ETA because the CR is too high. People argue against turboing an eta because of the shitty head (which you already knew). Only uninformed people would argue that 9:1 CR is too high for boosting.
                            '88 325is
                            VP UT of Austin Autoholics
                            BMWCCA 380364
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Ah, OK.
                              I went through and read a bunch of boost related threads, and it seemed the compression was mentioned often.
                              john@m20guru.com
                              Links:
