N54 IC fitment (m20 turbo)
  • ky0u
    • Dec 2012
    • 808
    Hi, I'm planning out a boost build for my 325is, thing is, I'm also planning on upgrading the IC on my e92 335i. Since I'll have the OEM IC hanging around afterwards, I was wondering if this this something I can use for the m20? I know there's probably fab work involved, which isn't too much of an issue, the question is, is this something worth doing? I'm not aiming for crazy numbers, around 250-300 whp at most. Would the n54 IC be up for the task or is it too restrictive?
    Web Designer / Front End Developer
    My Portfolio & Website
    IG: @w_illriderz
  • varg
    Florida Turbo Man
    • May 2014
    • 3439
    Flow should be fine and dimension wise it might fit between the valance and the core support behind the slots, but the end tanks and angles of the inlet/outlet are most likely going to be a dealbreaker.
    IG @turbovarg
    '91 318is, M20 turbo
