276/268 reground camshaft 2.5 or 2.7i
  • GUERONASTY
    • Aug 2011
    • 811
    Recently acquired a rebuilt, ported & polished 885 “i” head that has a Schneider 276/268 regrind. I’m currently running a stock ETA bottom end with a 885 “i” head on boost / Megasquirt. I’m oil fouling plugs so I’ll be taking the engine out for a rebuild. I’d like to swap the new ported and polished 885 “i” head with 276/268 cam while I’m the process. Not sure if I should rebuild my ETA bottom end with “i” pistons or run all “i” bottom end. From what I read the ideal thing would be ETA bottom end, “i” pistons and 885 “i” head. My concern is if the cam would work well with that set-up??
  • GUERONASTY
    • Aug 2011
    • 811
    Regrind cam card
    Image F8-EBFB9-F-608-F-4378-AA9-C-3-FED5-F4-D2651 hosted on ImgBB
    • digger
      • Nov 2005
      • 6198
      the better the engine is when a mild NA engine the better it is under boost. the cam will be fine
      • ForcedFirebird
        • Feb 2007
        • 8300
        That's not a very large cam, it will work fine. With longer duration cams, you want more static compression to take full advantage.
        Yes, the budget stroker is the way to go. To use "I" pistons the block needs to be decked about 2mm. It will put you over 9:1 compression and it will love the boost. As Digger said, the better the NA engine is, it will just be amplified by the boost - so start with the best you can.
        Another budget build that works well with turbo is use an 84mm crank from an m52, eta 130mm rods, and don't deck the block. This is closer to stock b25 compression, uses the good piston/head design, but leaves a little large quench.
        john@m20guru.com
        Links:
        • GUERONASTY
          • Aug 2011
          • 811
          What would be more cost effective for a budget stroker? I have everything for the budget stroker. Either having the block decked 2mm. Or sourcing a m52 crank the second option, usually $75-125 locally?
          And by “... ,uses good piston/head design” do you mean “i” pistons & head for the m52 route?
          • ForcedFirebird
            • Feb 2007
            • 8300
            They are going to cost similar, but with the added machining expense of either turning the crank and re-balancing it, or modifying the pistons to clear the bob weights - as well as the added expense of a crank spacer for the front main seal. So, you save the $$ on the block decking, but add machining costs. If you know someone, or have access to equipment, this can be a deciding factor. Many people have small lathes in their home garages, not so many have mills capable of decking a block.
            john@m20guru.com
            Links:
