M20B28 Dyno Results
  • SGT StudMuffiin
    • Aug 2015
    • 112
    M20B28 Dyno Results
    Edit: I can’t embed a video using Tapatalk so here’s a picture on the dyno. Well after years and years of chasing issues, stupid people blowing shit up, and just general bad luck, Marina is finally making some real power! She made 460whp/440wtq on a mustang dyno which more than satisfied my goal of 500whp on a dynojet. Some details: Forged M20B28 using M52 crank and 8.5:1 on E85 and 20psi. Precision 6262, Bimmerheads 280/274 cam in an otherwise stock head For next season she’ll be getting oversized valves, larger throttle body, and some porting on a flow bench to hopefully keep the power on a little higher and just more general efficiency. Sent from my iPhone using Tapatalk
  • reelizmpro
    • 9559
    That's impressive! I'm currently building a 2.7 liter 325i turbo stroker and hope to get at least 300rwhp with 14PSI. What headgasket are you running? Injector size?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • SGT StudMuffiin
      • Aug 2015
      • 112
      Cutring gasket and 80lb injectors at 85% duty fed by a Walbro 485 Sent from my iPhone using Tapatalk
      • McGyver
        • 4636
        Are you documenting your build anywhere? I'm just about done building all my MegaSquirt stuff, which is going to go on an m20b25 while I build an m20b27.
        • SGT StudMuffiin
          • Aug 2015
          • 112
          I’ll putout a post soon outlining my whole build Sent from my iPhone using Tapatalk
          • reelizmpro
            • 9559
            No, mine is just a stock rebuild with studs which should be enough for my goals ...nothing radical. I'm going from 11psi 2.5L to 14-16 Psi 2.7L and Garrett T4/T3 hybrid turbo on my M tech convertible.
            88 M3 - LACHSSILBER
            • Dunzo
              • Jun 2016
              • 28
              I'm really digging your engine build and the color of your ride. I was hoping to hit similar numbers on the same setup but with pump gas and meth. Is that feasible? Or should I just go for E85?
              If I didn't start a build thread did the build really happen?
