purpose of fuel regulation relay attached to airbox?
  • 5150ct
    • 79
    any body have any idea what the purpose of this is and if its worth paying almost $200 dollars for? Mine is missing completely and was wondering how much difference this part makes?
  • 5150ct
    • 79
    i guess its called the barometric pressure sensor upon further research. Mine is missing. I dont know how important it is, but it costs over $200 from the dealer. is it worth buying or just leave it as is?
    • Acet
      • Jan 2014
      • 64
      I wouldnt pay 200 for it..
      • 5150ct
        • 79
        Is it something the car needs to run correctly, or doesent make a difference in operation. I live in Ca. 20min from the ocean so im pretty much at sea level. I was reading that with the sensor missing or in operative the car calculates ratio at sea level anyway. Anyone have any input on this?
        • TobyB
          • 5293
          How's your mileage?
          I'd go looking in the pull- a- parts...
          the M20 etas had one, too- but I don't know if they were the same. Neat inside-
          really DOES look like a little mechanical barometer hooked up to a variable
          resistor...
          t
          • Chuck C
            • 104
            Not worth the $200. Don't worry about it being gone.
            • Jaxx_
              • Dec 2009
              • 1880
              My car ran fine on stock management without it. I'm guessing it only makes adjustment from 1atm if you are at higher altitudes... worst case is that you will run 10% richer for each 1000m above sea level.
              • jeffnhiscars
                • Jun 2011
                • 6011
                The cover has been off mine for years and at some point the slide arm moved which caused a high idle. Easy fix. Yes, it's an altitude compensator and no, you def don't need it.
                If they are worth that much maybe I should sell mine :)
                Alice the Time Capsule
