1.8i m10 rebuild questions
  • ZomBAR15
    • Aug 2014
    • 103
    So i just picked up another m10 for rebuild at the local pick and pull yard. Will be taking it down and giving it a basic rebuild, rings, bearings, gaskets and all that good stuff. My question is, what are yhe factory torque specs, and tolerances that i need to know?
  • packratbimmer
    • Dec 2009
    • 1335
    Pull the head and check the block for cracks (center head bolt, exhaust side) - Then get a Bentley for all of your specs.
    Good luck
    • TobyB
      • 5264
      ...and measure the pistons carefully...
      after you buy the Bentley.
      t
      • Smelser
        • Feb 2011
        • 633
        bore it out (its 30 yrs old) and get new pistons, they come with new rings. and a mild cam even. do the entire head, new springs rocker arms, retainers and recomend rocker locks over the stock holding springs if your gonna see any RPM beyond a daily driver
        sigpic1984 318i Total conversion to a DIRT race car.
        Check out our build on facebook @ www.facebook.com/brewstermotorsports
