M10 Issues
  • Peterbuilt84
    • Oct 2015
    • 36
    M10 Issues
    Hello,
    This is my first post on this forum. I recently bought a 1984 318i pretty much sight unseen. When I bought the car it had a big fuel leak at the injector rail which I was told was the only issue with the car. I fixed that but the car still ran terribly. After I was able to run it during the day I noticed that there was a ton of white smoke coming out of the exhaust. I popped off the radiator cap and there was no water visible. Then I checked the oil and it looked a bit milky. Those indicators and the fact the car has zero power leads me to believe the head gasket is blown.
    The car has all new suspension (with receipts) and is in really decent shape overall. I think the best step would be to take the motor out and rebuild it. I've rebuilt a motor before but have never worked on BMW's. Is this something that can be done relatively easily? How much would all the parts cost? I looked up pistons and main/rod bearings and those look to be about $600.
    Or should I just sell it and move on?
    Also should add I bought this to be my daily driver. Was looking for something fun to drive and also got good mpg.
    Any input would be greatly appreciated!
    (Here are a couple pics)
    Even found this link with all the info on the car:
  • aintnothang
    • 743
    Its begging for a swap.
    • Peterbuilt84
      • Oct 2015
      • 36
      Yea, that's originally the first thing I thought. Trying to stay as low cost as possible though.
      • thebutterson
        • 463
        There's a lot of M10 info over at 2002faq.com. Try and dig up the "shadetree" articles that were written by the guys at metric mechanic years ago. It covers an M10 rebuild. The M10 is a pretty simple engine. I've never rebuilt one but I did swap in a used short block and put a rebuilt head onto it. It was pretty easy. There's a special tool for removing the camshaft though. I imagine if you have rebuild experience you'll do just fine.
        • Jaxx_
          • Dec 2009
          • 1880
          Honestly a junkyard motor will be cheaper and more fulfilling than rebuilding the m10. Those motors can be found for cheap, most people can't even give them away. Consider the time and labor for rebuilding that motor and the fact you'll still have a 318. I love mine, but as soon as the motor is done I doubt I'll rebuild it.
          • Peterbuilt84
            • Oct 2015
            • 36
            Found and saved the articles you mentioned. Lots of good info, thanks!
            One of the reasons I'm considering rebuilding the motor is I haven't found a used one for a decent price. I found one that was $600 and that's about it. Maybe I'm not looking in the right place for them. It isn't the ideal motor but it supposed to get good mileage which is one of the main reasons I decided to get a 318.
            • packratbimmer
              • Dec 2009
              • 1335
              Try popping a head gasket on it. They are cheap and the job is easy. The early 318i is the lightest body out there. A properly tuned M10 can be a lot of fun in a light car. I drove them for years starting about 1994. I could notice a difference in "performance" when I had a passenger. If you are out to win a race, then no. If you would like a fun car that you can rev to the limit with no complaints all day long and get a grin on your face every time, go for it. If the head is not cracked, you could get it running for under a $100
              • E30_Pare
                • 7801
                Dump some headgasket fix and call it a day. Cant get cheaper than that and if it works it works.
                DREWLIENTE
                1$ PShops PM me
                • Peterbuilt84
                  • Oct 2015
                  • 36
                  I have a line on a whole M10 carb motor that I should be able to swap my efi parts onto. If that doesn't pan out I'll just take the head off.
                  As someone who has worked on a motor that was done to, I can't.
                  • thebutterson
                    • 463
                    Is it from an E21 or a 2002? The 2002 blocks have different holes for the engine mounts and will require custom mounts. The E21 block will bolt up but is missing two vertical bolt holes for the lower transmission cover. The cover will still bolt on to the horizontal holes though.
                    You'll probably need a cover for the carb fuel pump too.
                    • Peterbuilt84
                      • Oct 2015
                      • 36
                      Great info, thanks! I believe it's from an E21. Need to check for sure. Fabbing something up isn't an issue for me but dropping something in is much easier.
                      Sent from my SCH-I535 using Tapatalk
                      • TobyB
                        • 5297
                        This often isn't as easy as it seems- the E21 injection had ports in the head on some versions,
                        and swapping bits gets a bit tricky- at the least, you'll have to swap pans, oil pumps,
                        etc.
                        First, make sure it's really dead. A small coolant leak and a bad spark plug wire
                        aren't good reasons to swap an engine. You'll need to diagnose it anyway to make
                        sure you know what's going on, and that you fix the problem. And it's not hard to sort out...
                        Throw coolant in it, and see where it goes. Do a quick compression and leakdown test
                        while it's running. Then you'll have a better idea of what you have now.
                        If the engine really is losing coolant internally, my suggestion would be to pull the head off it and see. Often, the M10 head gasket
                        goes- and nothing else does. Or the head gets damaged, but the block survives-
                        they're HORRIFICALLY stout.
                        And tossing a head back on is the work of another evening or so. I've done a head
                        gasket in 4 hours, when I had to...
                        Don't panic,
                        t
                        • Peterbuilt84
                          • Oct 2015
                          • 36
                          etc.
                          Don't panic,
                          t
                          Thanks! Appreciate the input! The motor I have a line on was offered to me for free, all I have to do is pick it up. I think it's worth my time just to have the spare parts.
                          After a little test drive after I fixed the fuel leak there was still a real issue. I pulled the plugs and they were some of the worst I've seen. Replaced those with no difference. I think the head gasket is just really blown. I agree a compression and leak down test are in order. Just haven't had time. Working six days a week full time and going to school is the real issue (I really don't mind the work).
                          It is reassuring that these motors are stout. I really hope it's as simple as putting a new head gasket in. At this point I'm convinced it's worth keeping either way :) Lots of good input from this forum. It was also reassuring when I looked in the car after it rained and found no leaks anywhere!
                          • Smelser
                            • Feb 2011
                            • 633
                            I can use any and all M10 parts. the last night at the track for us, head gasket went, dumped coolant into the oil and the engine seized solid on the track. havent looked to see what parts are junked. But I am assuming its the third crank for me this year that is toast. I need cranks, rods and blocks and pistons from the block. I am running low but also live near niagara falls if anyone has anything.
                            sigpic1984 318i Total conversion to a DIRT race car.
                            Check out our build on facebook @ www.facebook.com/brewstermotorsports
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              I had an M10 for 17 years and gave it headers, aluminum flywheel and a 5 spd. The motor itself was never touched and I never got over 24 mpg which is almost exactly the same (actually slightly less) than my ETA and Cabrio get
                              Still, you have to love the way the m10 e30 handles.
                              Alice the Time Capsule
