Couple more things to remove and then off to a machine shop for inspection/cleaning and a head / valve job.
coolant temp. sender housing
fuel rail, fpr, injectors
manifold with icv, tb and tps
Can I safely remove this cold start valve and run without it ?
why does this manifold have to be so damn ugly
can't get this 17mm nut on the pulley off
stock bottom end
every bolt/washer is in it's own bag
Doesn't look to bad, once I know for sure it's straight and good I'll start ordering all new gaskets/lines/bearings. Thinking about maybe painting the block once it's clean and doing something with all those aluminum parts, powder coating maybe ?
stock bottom end
