ETA Head Gasket troubles?
  • LateFan
    • May 2013
    • 4414
    1986 eta. Closing in on 200k miles. My son and I found this car about 7 years ago, have gone through most systems except engine internals. A couple of years before we got it, the PO's teenager let it overheat and cracked the head. A small town mechanic put a "good used" head on (we were told he pressure tested it) along with a water pump, timing belt, and radiator. No information on whether it was skimmed flat. He wouldn't have had access to the good quality head gaskets there - probably the local NAPA. It's been trouble free for us once we got it sorted. Drove it 1700 miles to his new town with no issues and the new manual we had just swapped in.
    He's far away now, but reports some goo on the dipstick.
    No white smoke.
    Nothing showing in the coolant.
    No overheating.
    There has always been a right front oil seepage down the block from the head gasket.
    I'm trying to help diagnose - is this a minor issue, and just keep fresh oil in it? Or the tip of the iceberg and we need to pull the head?
    Is a leak-down test the first step? He's parking on the street with minimal tools there, so it would go to a shop to test.
    A month ago before an oil change....
Name:	a month ago.JPG
    This week.....
  • e30davie
    • Apr 2016
    • 1788
    I personally would be changing the oil and then monitoring the oil and coolant very closely as a good start. You can then also have a good look to see how much schmoo is in the sump. The schmoo on the end of the stick doesnt inspire confidence but you are only really going to know if you have an issue if you do a coolant system pressure test.
    • cheffy30
      • Sep 2016
      • 1159
      not a good sign by any means. change the oil. watch coolant levels carefully. document everything. mileage, amounts, etc. outside HG leaks are not as worrisome as internals. prepare for the worst. new head. sent from hell using Tapatalk
      '90 325i sedan daily driven
      '85 325e coupe also a daily
      • LateFan
        • May 2013
        • 4414
        Is the biggest danger that you’ll contaminate the oil and quickly ruin bearings?
        Oh - another question:
        Is the coolant heavier and that’s why there’s a dab on the end of the dipstick? And would that mean it’s getting sucked up by the oil pickup at the bottom of the pan?
        Thanks -
        • e30davie
          • Apr 2016
          • 1788
          Water has a specific gravity of 1, engine oil is about 0.82. So yep, oil sits on top of water, water will tend to sit on bottom of the sump. Does the dip stick sit on the bottom of the sump? i wouldn't think so. makes me think you have more water in there than you think.....
          And yer, anything contaminating your oil isn't good for anything. Would not recommend.
          • LateFan
            • May 2013
            • 4414
            OK, thanks. This is all good to know. He's going to get a coolant pressure test and a leak-down test next. Could be the gasket, could be a crack in a passage I s'pose.
            I'll ask him what the oil looked like when he drained it. The trick of replacing one head bolt at a time and torquing it down seems like a temporary band-aid to me. What we don't know is the quality of the work when it was done, whether it was skimmed flat, and what kind of gasket went on.
            • ForcedFirebird
              • Feb 2007
              • 8300
              There isn't anywhere for the oil and coolant to mix on an m20, even with a blown HG. Only reason oil/coolant mixes in an m20 is a cracked head - which is EXTREMELY rare on an eta (they don't have #6 cam journal, and have thicker castings). If you study an m20 HG, the oil supply is right next to a head bolt, and the oil returns are all the way outside the cooling passages, and outside the block deck, even. If you had mixing from a blown gasket, the car probably wouldn't even run the head would have to be so warped.
              BUT:
              Let the car sit for a day or two, then pop the oil plug out. If there is indeed a significant amount of water/coolant it will come out first. Then plug it up when the oil starts flowing and take note of the amount of water/coolant.
              If there's a slow leak into a chamber, a pressure test won't be easy to catch, but in turn a leak at there will also pressurize the expansion tank.
              It is totally normal to have SOME moisture in your oil (ever notice the "cream" on the bottom of oil caps?). An engine is a "reverse" condensate. Just like a cold beer sweats on a hot day, the inside of the engine will condensate as it cools off, thereby adding a little water into the oil every time the car shuts down. Many people who take a lot of short trips almost NEVER let the car get to operating temps. That moisture in turn builds up in the oil - the vapor never gets burned off unless the oil temps reach operating. This is the main reason you are supposed to change oil every "3mos" or xxxx miles - oil breaks down when adding/boiling water in/out of it, even if the mileage is low.
              john@m20guru.com
              Links:
              • LateFan
                • May 2013
                • 4414
                That is really good info, thanks. We've never touched the head bolts because we were told they're a one-use bolt and you shouldn't re-torque them. It's never gotten hot while we've had it. I'll send him the oil drain idea. Had he known there was a question, he would have watched it drain into an open pan, so we don't know what it looked like. I told him another 5 qts of oil is a cheap way to learn some things.
                Yeah, the condensation thing is hard on city cars that only get little errand trips.
                Depending on what we find, I was just thinking I'd call you to see if you had any good eta heads on the shelf.
                • cheffy30
                  • Sep 2016
                  • 1159
                  if the HG is blown in the right place... I think only a couple places... coolant will leak in the oil and badly. I know from experience. the cracked head... also experienced... a pressure test is a must.. it's expensive for a new and properly fit head... but I feel good about the whole engine now. I'm at 305k. if that makes any sense at all. sent from hell using Tapatalk
                  • LateFan
                    • May 2013
                    • 4414
                    Thanks. I'm thinking if the shop in the little town knew more, or were paid to do it right by the PO, we wouldn't be asking all these questions. If we pull it and find a crack, then we'll need a good solid one to machine. Makes me wonder if they welded up the crack and put it back on...
                    I need to learn about measuring warpage, and heat straightening, so they don't just machine it flat and the cam binds. And what the minimum thickness is and where to measure that. Probably threads on that here on r3v somewhere.
                    These machine shop videos are good. John Edwards was his name. He sadly died in 2017 I just read.
                    • e30austin
                      • 15382
                      $10 says the person, that performed the repair, used a VR head gasket set. this is exactly what happens, when those fail.
                      • cheffy30
                        • Sep 2016
                        • 1159
                        Originally posted by LateFan
                        Thanks. I'm thinking if the shop in the little town knew more, or were paid to do it right by the PO, we wouldn't be asking all these questions. If we pull it and find a crack, then we'll need a good solid one to machine. Makes me wonder if they welded up the crack and put it back on... I need to learn about measuring warpage, and heat straightening, so they don't just machine it flat and the cam binds. And what the minimum thickness is and where to measure that. Probably threads on that here on r3v somewhere. These machine shop videos are good. John Edwards was his name. He sadly died in 2017 I just read. https://www.youtube.com/user/fiatnutz/videos
                        .002 is factory acceptable spec. I believe. some cracks can be welded. others can not. I bought an new AMC 885 head for my 325i. I didn't want to trust a used one... who knows how long it would last. sent from hell using Tapatalk
                        • LateFan
                          • May 2013
                          • 4414
                          I'll bet $10 on the local tractor store or NAPA. They do have a NAPA.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            VR gaskets leak oil on the exhaust side
                            I will beg to differ. In my personal experience (probably 50 m20 HG's and I even have 7 cracked heads on my shelf), I have NEVER seen oil/water mix outside of a cracked head. In fact, in Feb one of the rental drivers let the m20 get so hot, water instantly boiled off the intake manifold. I didn't have the IR gun handy, but based on experience the head had to be 300+f. Still no mixing, even though we could see coolant spewing out of the middle cylinder during a comp test.
                            Look closely at an m20 HG and find where the coolant and oil has a chance to mix. There's 6 large oil drain holes on the exhast side, and one tiny oil feed right next to the middle head bolt. All the cooling passages are at least 1/2" (12.5mm) away.
                            john@m20guru.com
                            Links:
                            • TobyB
                              • 5286
                              Hey! I live in a small town, too, here!
                              t
                              whose shit tends to blow up, so nevermind.
