Dyno mystery. Need your help
  • dvallis
    • Oct 2015
    • 1474
    Car was running 100% when we pulled into the dyno garage. Ran great, idled great. Once it was bolted to the dyno, in neutral, BEFORE any pulls, -something- happened.
    What The F?
    Idle dropped from steady 1100 RPM to ~900 and stumbling
    AFRs went rich
    VE table is WAY low. In the 30s
    Car would not make low end power
    Tuner could not add timing without getting ping
    It backfired a couple of times. Never did that before, ever
    Nothing mechanically obvious (rattles, bangs)
    MAP & boost hoses all good and tight
    What in the frigging he'll could have happened? Maybe:
    1. Nuke timing gear slipped?
    2. Injector stuck open
    3. ?
    4. ?
    We're going to check 1, 2. Then test compression. I'm damn mystified. Any ideas?
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
  • Old525i
    • Oct 2015
    • 32
    Usually, the cause of a problem is very simple. #1 seems to make sense: if the timing gear slips, it could be the reason for backfiring.
    What does "VE table is WAY low. In the 30s" mean?
    • digger
      • Nov 2005
      • 6147
      Compression check, leak check, timing check, fuel pressure, oil pressure ?
      • Nader393
        • Dec 2015
        • 408
        Check for spark. Was a spark plug wire dislodged while setting up the dyno? And why would it ping if AFRs are rich?
        '91 325i
        • dvallis
          • Oct 2015
          • 1474
          3. Compression
          4. Leak
          5. Fuel pressure
          6. Spark plugs
          7. Plug wires
          We'll be looking into all this. Still VERY frigging weird for the engine to suddenly go stupid rich
          2002 E39 M5
            • 34839
            FPR failure?
            • dvallis
              • Oct 2015
              • 1474
              It was #1. Frigging adjustable timing gear threw a bolt and clocked to the stops
              2002 E39 M5
              • Nader393
                • Dec 2015
                • 408
                Surprised by the lack of locking washers (serrated belleville type) under those screw heads. Do that in addition to thread locker if you decide to keep that pulley (I wouldn't keep it, if you're back to stock gasket thickness). Hopefully that pinging sound you described wasn't your valves making contact with the pistons.
                '91 325i
                • digger
                  • Nov 2005
                  • 6147
                  are you sure those bolts were properly torqued ?
                  also the lack of a washer under the central cam bolt should be rectified IMO as the bolt head doesnt have a big flange and high grade bolts onto AL is a risk of relaxation/loosening without a washer or lots of contact area
                  my guess (iirc its a 272 lobe and aftermarket deeper reliefs) is that you should be ok based on the exh valve to piston clearance is normally shedloads
                  • dvallis
                    • Oct 2015
                    • 1474
                    I -thought- they were properly torqued but obviously screwed it up. :-/ Nuke Gear is going in the trash. Back to stock.
                    Compression test after re-establishing timing will tell us if the valves survived. We had something like 0.125" p2v. Fingers crossed.
                    2002 E39 M5
                      • 34839
                      Glad you found it and it was simple. funny because I have a cheap Chinese adjustable timing gear (even the +/- marks are labeled backwards) and it's worked perfectly for years.
                      • digger
                        • Nov 2005
                        • 6147
                        To be fair ive used my Nuke trouble free for the last 13 years and done at least 4 or 5 adjustments without issue (touch wood). It wouldn't be hard to design something better though. Moving around the cam was well worth the admission price from a power/torque improvement.
                        • dvallis
                          • Oct 2015
                          • 1474
                          So who is actually running mechanical advance to make more power? How many degrees and with what cam? I'm running a 284/272.
                          Let's hear a roll call.
                          2002 E39 M5
                            • 34839
                            I didn't use it to make more peak power necessarily - I used it to tweak the torque curve to get the most overall area, instead of a high peak (but losing torque/power everywhere else). There's a sweet spot where you don't lose much peak power but you get a lot more low end torque.
                            a bit of a pain to adjust on the dyno though, especially since I have a cam sensor and have to take all that apart to get to the timing gear.
                            • dvallis
                              • Oct 2015
                              • 1474
                              Thanks for the tip nando. We might keep the cam gear and dial in a bit of mechanical advance. How much does the M20 stock cam seem to like? We are running 284/272
                              2002 E39 M5
