Dyno mystery. Need your help
  • 2mAn
    Señior Mod
    • 20211
    Its all in the name... Nuke.
    I'll see myself out
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • dvallis
      • Oct 2015
      • 1472
      Owwwwww! That hurt! : - )
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1472
        Been starting at this pic for a while, wrapping my brain around what happened. When the bolts came lose, belt and outer shell of cam moved clockwise. Valves opened later with respect to TDC. We got maximum retard. (Me and the cam)
        The nuke gear can only move 6 degrees (I think) due to keyway length. Can't tell since I'm not at the shop. Each cam degree equates to two crank degrees, so we were at 12 degrees retard. That's a stupid amount but retard increases intake valve clearance we may be Ok.
        2002 E39 M5
          • 34830
          Originally posted by dvallis
          Thanks for the tip nando. We might keep the cam gear and dial in a bit of mechanical advance. How much does the M20 stock cam seem to like? We are running 284/272
          I have the same cam. I think I started at 0 and maybe have 5 degrees now? It's been like 10 years since I've touched it though.
          • dvallis
            • Oct 2015
            • 1472
            Thanks Nando. 5 CAM degrees or 5 CRANK degrees?
            2002 E39 M5
            • digger
              • Nov 2005
              • 5962
              IIRC you went 5 degrees of retard ?
              i think Tinkerputzer also with 284/272 with 3.1L found best was a little retarded (4 degrees).
              https://www.r3vlimited.com/board/for...64#post5789087
              i ended up with 5 to 8 degrees of advance and found it was best power across all rpm but that's not the norm (unless the cam duration is a little excessive)
              there is no universal rule
              • moatilliatta
                • 6121
                You could get an offset dowel pin if you don’t want to run the adj gear.
                @Zakspeed_US
                  • 34830
                  yeah, could be, I honestly don't remember. I could pull the cover off, but we all know that's not gonna happen, lol. I do know I tried both advance and retard, then settled on something that had the biggest area under the curve. That's where I met Steve (hoveringuy) and really wanted an engine with full variable Vanos...
                  The disadvantage to SOHC is if you advance the intake, you retard the exhaust, and vice versa. So there's a pretty limited range that works. You just have to try it and see what works best for you. But I find it unlikely that the stock cam with whatever random timing you get with a particular bock/head/gasket combo is going to be perfect out of the box. So it's worth experimenting.
                    • 34830
                    You could, but that's rather permanent, and you have to already know what the best adjustment is first.
                      • 34830
                      TBH, I don't remember. I think probably crank degrees. I did a couple passes with a few settings, then left it at what made the best overall curve.
                      Also sorry for clicking "edit" instead of "quote". Ugh, this forum interface... lol
                      • hasa
                        • May 2013
                        • 284
                        Any chance that valves have hit pistons and the retardation / being loose would be caused by that ? There may be many root causes. Loose bolts is one.
                        • TobyB
                          • 5182
                          The offset dowel washers are cool-
                          you oversize the hole, then use an offset washer to advance/retard the cam.
                          The domestics do this, so a set of washers is $6,99, and once you've done the
                          rudimentary machining, it's both very positively locked in place
                          AND pretty simple to change if you want to.
                          t
                          diy is sometimes less of a nuke.
                          • dvallis
                            • Oct 2015
                            • 1472
                            Update here. Was the Nuke Gear. We amputated and replaced with a solid gear 0/0 TDC.
                            Valves were not bent. (Wooooo!) Compression showed 210/211 psi on all 6. Ready for a re-tune, but I'm on vacation soon and our dyno guy is booked until after SEMA
                            2002 E39 M5
