Main bearing oil hole?
  • Maximumtune30
    • Apr 2021
    • 15
    I just put the main bearings to the block ( late model) and i noticed that one oil hole in the bearing does not match with the block. You can see the edge of the hole but it's a little off. THIS IS THE OIL GALLEY THAT GOES FROM THE MAIN BEARING TO THE OIL PUMP DRIVE SHAFT BEARING. There is a groove in the block under the main bearing so oil can get to the oil pump shaft.
    But should the bearing hole match?
  • 82eye
    • Jan 2009
    • 2011
    how do you propose to change it ? the bearings are all drilled the same and the block isn't going to change ..
    • Maximumtune30
      • Apr 2021
      • 15
      i would have filed the bearing hole slightly bigger, i found 1 used m20 bearing and the hole doesn't match with that either so i guess it's supposed to be that way.
      • TobyB
        • 5250
        Not a big deal on the mains- that groove covers you just fine.
        On an engine without the grooves, yes, you open up the hole in the main shell. They're positioned such that they're in a low
        loading part of the shell.
        I open up the oil holes in the crank exiting to the crank bearings a bit, too, with a die grinder. Seems to help a lot at sustained higher revs.
        t
        'cause boom.
        • 82eye
          • Jan 2009
          • 2011
          probably wouldn't hurt to do. i thought the difference would have been in the block casting. for what it's worth mine was the same, but the difference so small we never thought anything of it.
          • 82eye
            • Jan 2009
            • 2011
            thanks. good to know about the differences. have only ever seen the one type.
            now that's badass and cool. would never have thought of it.
