Piston ring end gap too wide...
  • Maximumtune30
    • Apr 2021
    • 15
    Hello
    ​​​​​​I have JE forged pistons with JE proseal rings, they have a 0.4mm minimum ring end gap I grinded one top ring gap too wide (about 0.65mm). Others are about 0.45-0.5mm. Is this anything to worry about, or should i just leave it as it is. Do i need to get new rings? This is a high compression NA engine with e85 fuel.
  • hasa
    • May 2013
    • 307
    I would leave as is and send it.
    • Maximumtune30
      • Apr 2021
      • 15
      Yeah, i put the bottom end together already. I staggered the ring gaps 180 degrees from each other.
      i'll loose a hp or two, but i guess it's better than having a too tight gap and blowing your engine.
      I feel kinda embarrassed that i overgapped the ring, but i don't think it will happen ever again ;)
      • pshooter
        • May 2013
        • 29
        You would want .005" per inch of bore dia top and.0055 " per inch of bore dia 2nd
        At minimum.
        • hasa
          • May 2013
          • 307
          At minimum.
          Yes as a thumb rule, but some piston manufacturers may recommend smaller values for N/A engine. Better read instructions of manufacturer as primary source of information.
          • TobyB
            • 5286
            Unless I was racing in a very tight group, I'd use it too-
            you're looking at a TINY loss in ring seal, at worst.
            Far better than leaving it too tight!
            t
            • ADEN
              • 620
              If you end up using it. Put the piston with the wider ring gap in no.6 more heat more expansion ;).
              • Maximumtune30
                • Apr 2021
                • 15
                Yeah thats what i did
