Fuel Sender problem. How to test?
  • Lippy
    • Jul 2022
    • 95
    So, my fuel gauge only reads a little over half when I fill it up. I'm assuming one of the fuel senders is bad on one of the pumps.
    What is the best way to test which sending unit it is? I have a 88 325i convertible and it looks like the 2 are different. I just need to figure out which one I need to buy. Thanks!
  • McGyver
    • 4636
    I did some of reading wasn't able to get a definitive answer.
    The two level senders work by changing the resistance as the float goes up/down with the fuel level. I think each should be 0-3 Ohms when full and either 35 or 70 Ohms when empty. Pull each out, test the resistance right side up (empty) and upside down (full). One of the floats may be stuck and just needs a cleaning to get moving again.
    wedophones.com has all the wiring diagrams:
    I didn't see a spec in the Bentley
    • reelizmpro
      • 9558
      First did it happen suddenly one day? Or was it like that when you got the car?
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • Lippy
        • Jul 2022
        • 95
        It was like that when I bought it in May.
        • Lippy
          • Jul 2022
          • 95
          Cool, thanks for the info.
          • Lippy
            • Jul 2022
            • 95
            I let this go over the summer and fall while I was still driving the car, but recently started digging into this issue again.
            My gas tank is mostly full. I tested the resistance of both senders in the tank and one was 9 ohm and the other was 9.9 ohm, which seems pretty close based on how much gas is in the tank.
            I'm not sure what to do. Maybe the senders are fine and the gauge is the problem? Thoughts?
            • tomstin
              • Mar 2015
              • 570
              As I recall, there are two different fuel gauges. I pinched the needle on mine when I had the cluster apart to replace the speedometer gears many years ago. Bought a fuel gauge off eBay. Ran out of gas going to work when the gauge said half a tank. Reach out to http://www.bavrest.com/index.html to see if they can provide any insight.
              2004 525i Manual - 1985 325E Coupe Manual
