M20 Weak spark, misfire on cyl 5 only
  • schlafr
    • May 2023
    • 8
    Haven’t had the car on the road as I bought it with a head gasket leak… replaced head gasket, decked head, valves adjusted, valve seals replaced, replaced all sparkplugs wires, distributor and rotor, all of that… had the car running somewhat fine until I magically now am getting a misfire on cyl. 5, already swapped injectors, checked compression, checked and changed spark plug, swapped coil wires, thing still doesn’t hesitate when I remove coil wire from cylinder. Makes no sense at all as I’ve replaced a lot
    Eyes raised on the CPS or coil itself but it should be misfiring on all if it was the coil… I don’t know what else it is as the head is fine and compression is good, any ideas lmk, maybe CPS?
  • tomstin
    • Mar 2015
    • 569
    Have you checked the wiring to the injector on #5? Agree, strange symptoms.
    2004 525i Manual - 1985 325E Coupe Manual
    • packratbimmer
      • Dec 2009
      • 1335
      Coolant getting into cylinder? Pressure test?
      • bangn
        • Sep 2011
        • 760
        what colour is the plug on number 5? is it fouling compared to the others?
        Boris - 89 E30 325i
        84- E30 323i
        • schlafr
          • May 2023
          • 8
          Yup, checked ground and and positive continuity, no wires internally messed, like I’ve checked everything and this is making no sense lol…
          • schlafr
            • May 2023
            • 8
            The old plug I pulled was completely black, electrode and everything.
            • schlafr
              • May 2023
              • 8
              Yup, compression test was 120, still got decent compression.
              • packratbimmer
                • Dec 2009
                • 1335
                I was meaning a cooling system pressure test.
                • bangn
                  • Sep 2011
                  • 760
                  Wont be an injector wiring issue unless youre unlucky enough to have a busted ev1 connector. These cars have a common power for all the injectors and the injectors fire off in pairs. So it would be two not getting a signal not just one.
                  If you've got a black plug then you're getting fuel. If you've swapped injectors you can eliminate a badly atomising injector.
                  I feel this will be either a bad lead, a badly seated/burnt valve or you have water being dragged in under the headgasket. If you have tried NEW leads on it and you've swapped round the lead with number 6 but the issue stays in pot 5 then you can eliminate an ignition issue providing youre 100 percent the contact inside your dizzy cap isn't worn way worse than the others on no5.
                  When you do your compression test are you testing each cylinder exactly the same and not having to crank one more than the others to get the same pressure? Tbh 120psi isnt fantastic anyway but so long as they all take the same time to crank roundabouts the same pressure thats all that matters.
                  Does it ping or did it ping? Did you flatten the block and check with a straight edge across the bores before putting the head on?
                  Boris - 89 E30 325i
                  84- E30 323i
                  • packratbimmer
                    • Dec 2009
                    • 1335
                    I have seen M20 engines carbon up bad enough to cause a serious lack of power. I agree that 120 PSI is starting to get on the low side. BTW: are you using copper NGK or Bosch spark plugs? I would stick to copper unless you are willing to experiment.
                    • schlafr
                      • May 2023
                      • 8
                      I got black plugs for all cylinders, suspicions on FPR or block warped, lost cause lol, tried everything, it still pings but absolutely no change disconnecting good wire
                      • schlafr
                        • May 2023
                        • 8
                        i have seen m20 engines carbon up bad enough to cause a serious lack of power. I agree that 120 psi is starting to get on the low side. Btw: Are you using copper ngk or bosch spark plugs? I would stick to copper unless you are willing to experiment.
                        ngk
                        • digger
                          • Nov 2005
                          • 6178
                          I am confused as to the symptoms. how did you verify weak spark on #5? is that what you meant? now all plugs are black?
                          • bangn
                            • Sep 2011
                            • 760
                            So all plugs are fouled?? First you'll need to ensure your TPS is adjusted correctly, test your ecu temp sensor isnt faulty, ensure your ignition timing, gaps and spark plug heat range is correct.
                            Low fuel pressure could cause the fouling, does it buck and surge when you put your boot into it? Drop power around RH Corners?
                            Boris - 89 E30 325i
                            84- E30 323i
                            • schlafr
                              • May 2023
                              • 8
                              I thought it was weak spark but it seems to be u known lmfao, it sparks but literally doesn’t fire, pull the coil wire and no difference, swapped injectors everything.
