Do I need an upgraded ECU with a Schrick 272 in other wise stock M20 engine?
  • bimmerdriver49
    • Jan 2024
    • 7
    Hello, I've got a freshly built completely stock e30 m20 engine except for the cam which is a Schrick 272. My engine builder told me it would run fine with a stock setup. But, the car runs noticeably more sluggish than my other e30 that is Completely stock. I contacted Bimmerworld, who sells the cam and they basically said they don't have any recommendations. Thanks much, in advance for any help trying to figure out if I Should upgrade the ECU and then, how I would go about determining what to upgrade to.
  • Panici
    • Dec 2009
    • 2575
    The WOT maps are open loop, so they have fixed fueling and timing.
    As you've changed the airflow with a cam, I'd guess you're rich in the midrange and lean up top.
    Before you swap the entire ECU, you should look at a "chip" tune. I would only trust an old head tuner for chip swaps, lest you be given an off the shelf Dinan clone.
    Personally I'd contact Mark D (https://dsylva-tech.ca) and see if he has anything specific for your ECU and cam setup.
    You could go down the road of a standalone ECU, but that will require hardware and wiring changes, and is probably overkill for your needs.
    • bimmerdriver49
      • Jan 2024
      • 7
      Thank you Panici for the tip. I'll contact Mark.
      • digger
        • Nov 2005
        • 6199
        sssquid also do chips
        • TobyB
          • 5296
          Me, I'd stick a wideband oxygen sensor on it, and see what's happening.
          THEN go from there.
          t
          • Panici
            • Dec 2009
            • 2575
            THEN go from there.
            t
            Not a bad idea. Maybe the factory WOT tune is sufficiently rich to handle the extra airflow?
            • digger
              • Nov 2005
              • 6199
              often the idle timing needs some fudging amongst other things when the cam is bigger so there is slightly more to it than the AFR are ok therefore GTG
