M20 crank damper wheel diameter
  • zaq123
    • Jul 2016
    • 1486
    Does anyone have the exact damper wheel dimeter (surface where TDC mark is)? I want to mark it up for 15-20 degree marks to set the base timing with the light but its bolted to the engine and it's not easy to get the exact measurement with its bolted and the engine bay.
    Thank you
  • digger
    • Nov 2005
    • 6082
    D188mm
    • zaq123
      • Jul 2016
      • 1486
      Originally posted by digger
      D188mm
      Thank you sir. That's at the round portion with the mark on it, not the outer toothed side.. just confirming
      • digger
        • Nov 2005
        • 6082
        the part that has O | T on it
        • hasa
          • May 2013
          • 304
          Repeating the fact that trigger wheel has 60(-2) teeth distributed evenly on 360 degrees. It's fairly easy to make for example 12 degree advance mark on the pulley with white paint pen.
          I always check my base timing (trigger offset) with this method when using aftermarket engine management.
          • zaq123
            • Jul 2016
            • 1486
            yes. Or 2πr​/360 for an exact degree. Or 1.64mm for each degree on the surface of the wheel where TDC mark is
