Fresh Rebuild Coolant in Exhaust/Exhaust in Coolant - Cracked Head?
  • digger
    • Nov 2005
    • 6205
    i think the first reply still stands.
    • TobyB
      • 5297
      All I can add-
      Get it hot and try pressurizing #6 at TDC compression. (basically, do a hot leakdown test)
      My not- very- clever vote would be a crack somewhere which
      only opens up when hot.
      Is the head corroded?
      I once put together an M10 that had corrosion in a water jacket that breached into a head bolt hole,
      and only did it hot. Eventually, it left a trail on top of the head where coolant escaped from under the washer.
      If you can't find anything else, yes, I'd try a different head. Especially if the gasket seal this time looks good as well.
      Pictures always help, too, as sometimes a picture sees in ways eyes don't...
      t
      • zaq123
        • Jul 2016
        • 1569
        tried this thing (link) into your expansion tank lid? if, no try it. -25 inHg of vacuum will find your crack or wherever the coolant ig going.
        https://www.harborfreight.com/coolin...kit-64985.html
        2 min test vacuum test with this endoscope into your spark plug holes
        https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
        • e30austin
          • 15382
          you should post some pictures of your cylinder head. top side with emphasis on the cam line, and the mating surface.
