ABS Unit Clog? Need help from someone’s who’s informed on how the ABS unit works
  • ScottySbk
    • Aug 2022
    • 34
    So basically I was bleeding brakes and my passenger side won’t bleed. I followed it all the way to the ABS and still cant get fluid to come out that port. Is there something internally that’ll open and close that port? I’m not really sure. Every other line flowed fluid besides the passenger side one at both the bleeders and ABS unit. It’s got a little over 87k miles on it as of now.
  • 82eye
    • Jan 2009
    • 2109
    if there is fluid up to the abs but not after the abs unit is in fail. the fix is replace or delete.
    • TobyB
      • 5298
      Have someone put their foot on the brake and then very slowly and carefully crack the fitting.
      It's not uncommon for a small plug of congealed goo to block the bleed fitting...
      t
      • zaq123
        • Jul 2016
        • 1572
        spot on.
        if delete isn't an option.. here is your best bet. Money well spent IMO. https://mtechniqueabs.com
