85 M20B27 Valve Adjustment
  • tomstin
    • Mar 2015
    • 569
    I'm having trouble adjusting the #5 exhaust valve lash. It is always noisy. It's been trouble for years, before and after I had the head serviced while replacing the head gasket. On my last attempt I replaced the eccentric on the rocker...no help. There are a lot of potential variables between the length of the valve, rocker shaft wear, rocker wear itself and cam shaft. Or a little of all of them.
    I could try to "sneak" the cam out the front enough to replace the rocker. A bit tedious and risky on damaging something along the way.
    Has anyone had experience with valve lash caps? Seems like an option but I've never used them.
    Other ideas?
    2004 525i Manual - 1985 325E Coupe Manual
  • digger
    • Nov 2005
    • 6180
    You probably need to explain what trouble adjusting lash mean. if the adjustment is correct then the noise is not caused by the adjustment and something else is worn or the noise is an injector or something else.
    you should be able to feel if the adjustment is correct and there is the option of adjustment with feeler between the cam lobe and foot of the rocker (reduced clearance if you check there instead of at the eccentric due to the rocker ratio)
    if there is wear, then the chances are there is wear in other places so changing 1 rocker makes no sense unless it has failed
    • tomstin
      • Mar 2015
      • 569
      Digger, I can't seem to get the gap between the top of the valve and the eccentric on the rocker into spec. I forget how tight I could get it, but it was a few thousands too loose and therefore noisy.
      It appears the thinest lash caps are .080 and I'm a bit worried with those installed the overall lash maybe too tight??????
      • McGyver
        • 4637
        Remove the eccentric and check it for a flat spot. Running it too loose could have damaged it or wore it out. Swapping on a new eccentric should be very simple.
        I have never seen an m20 with lash caps, I've never needed one, and I don't think using them is a good idea. Your valves should be able to be adjusted into spec. If you can't get them into spec, figure out why and fix that problem.
        • digger
          • Nov 2005
          • 6180
          Have you ever been able to do the adjustment properly so on this engine? do you know the history of it has something changed to cause this? what cam and rockers etc etc. you really need to find the root cause. how does the engine run?
          There are oversized eccentrics for reground cams where the base circle of the cam is smaller.
          • tomstin
            • Mar 2015
            • 569
            No history on the engine. Judging from the cylinder walls when I pulled the head for the head gasket, not a high milage engine. Odometer has over 200k so odds are good this may not be the original engine. I have no complaints on how the engine runs other than the noisy valve.
            As I mentioned in my initial post, eccentric was the first thing I thought to replace. I want to take another crack at this after the holidays and have all my options available once I take it apart. Maybe I'll add my dial indicator to the list and measure the cam this time.
            • digger
              • Nov 2005
              • 6180
              Did you replace it with on oversized eccentric or a standard one?
              • tomstin
                • Mar 2015
                • 569
                Looking back at receipts I used a Febi eccentric from Pelican. Where can I find an "oversized" eccentric? I was not aware they existed. Thanks Digger!
                • digger
                  • Nov 2005
                  • 6180
                  Refer to Post #5
                  • TobyB
                    • 5286
                    +1 for an oversized eccentric-
                    I have had at least 2 budget rebuild heads with cleaned up
                    worn- but- serviceable parts and reground cams that have needed one or 2 oversized eccentrics.
                    Lash caps work, too, but are just one more loose part that's easy to lose.
                    However, make sure that the pad on the rocker isn't getting eaten by the cam-
                    that can open up the lash, too. Cam wear is easy to spot, but
                    the pad can be pretty easy to miss...
                    t
                    keeps a few spares in the racing toolbox
                    • tomstin
                      • Mar 2015
                      • 569
                      THANK YOU DIGGER! I finally got time to install the .020 oversized eccentric and was able to easily get the valve lash correct. No more valve noise! The oversized eccentric adjustment hole was slightly smaller and my purchased tool would not fit. However, I had developed my own, finish nail precisely bent, worked perfectly. Thanks to all that contributed to the discussion!
