ITBs and brake booster
  • zaq123
    • Jul 2016
    • 1572
    With ITB setup, vacuum booster gets its vacuum from only one runner, #3 cyl in the case of RHD ITBs. Rama states in his instructions that vacuum from one cylinder is such stronger than the vacuum block... which makes sense.
    Does this mean that the check valve with open/close open close or pulsate with every closure of that intake valve? Unlike with the vacuum from one TB where the valve remains open while the engine is running and only closes when it's off.
    I had new ATE check valve just felt apart internally within 1k miles so I wonder if I need more robust valve or if it was just a defective check valve.
  • digger
    • Nov 2005
    • 6213
    iirc i am using the 90 degree version 34331156579, i dont recall if i have it connected to 1 or 2 cylinders (360 degrees apart). I am using the e90 booster
    • TobyB
      • 5298
      Your logic makes sense- every time you 'recharge' the booster, that valve's going to be
      popping open and closed a lot. And probably a lot more abruptly.
      For no good reason other than 'because?' I think I'd put in a known- good used
      valve next, and see how it does. When it then fails, then start looking for a tougher solution.
      t
      has lost trust in new parts.
