Shim at M20 flywheel - how thick?
  • Chuck-Michigan-e30
    • Jun 2024
    • 9
    Hello,
    I have two shims (probably part number 11221262827). It fits between the flywheel and the 8 bolts going into the crankshaft. I have a ton of parts and ended up with 2 shims. One is 2.75mm thick and the other is 6mm thick. My engine is the 2.5L 1987. Which shim is correct??? Chuck
  • 82eye
    • Jan 2009
    • 1977
    ooooh ... they are all the same shim for m10, 2.7l e, and 2.5l i car. i know that doesn't help. i have one kicking around somewhere, if i can dig it up i'll measure it for you. the other question is - what is the other shim for ?
    • zaq123
      • Jul 2016
      • 1466
      Originally posted by Chuck-Michigan-e30
      Hello,
      2.5mm is manual transmission, 6mm is automatic if i recall correctly. Did you do a manual swap and auto shim is from that ?
      • 82eye
        • Jan 2009
        • 1977
        thanks for clearing it up. i never considered auto cars.
        • zaq123
          • Jul 2016
          • 1466
          yeah of course. The problem with using think auto tranny shim there is that your flywheel bolts will be hitting springs on the clutch disk and it will not sit flat against the flywheel.
          • 82eye
            • Jan 2009
            • 1977
            i'm running a lightweight flywheel and the shim gets deleted on install.
            • zaq123
              • Jul 2016
              • 1466
              I hope it's not an aluminum one. Because you def want that bolt torque plate with it. It's good idea with steel too hence the design.
              With my m20 2.9 stroker, I'm using BMW 320i flywheel, p/n 11221264517. which is 6.3kg vs. 325i one at 8.5kg. Using torque plate/washer with it.
              • Panici
                • Dec 2009
                • 2392
                Auto vs Manual as stated.
                Thicker spacer is for the Auto trans.
                '87 BMW E30 325is Turbo
                '99 BMW E36 M3 - - - '98 BMW E36 328i
