1987 325es crank no start
  • Fryedchicken34
    • Apr 2026
    • 11
    Good news guys, I have fuel. Got aftermarket cps from fcp. Now the car starts, and starts redlining until i turn it off. Might be because the PO deleted the icv but not exactly sure. Gotta figure out why that’s happening but it’s progress. Thank you all for your help!
    • zaq123
      • Jul 2016
      • 1562
      is the icv hose/port on the throttle body blocker off/capped when you are starting it? If it is, it shouldn't rev too high unless there is another huge vacuum leak somewhere after the throttle body or if your throttle body butterfly is too open.
      • Fryedchicken34
        • Apr 2026
        • 11
        Yupp it’s capped off, I unplugged the tps and it seemed to be a lot better, I think the tps was sending a wot signal for some reason. My gas pedal also seems to be getting stuck, the mount seems broken and missing a bushing, so that’s the next thing I gotta look at.
        • zaq123
          • Jul 2016
          • 1562
          TPS can send wot signal all it wants but if there is no air coming in, there is no high revs
          • Fryedchicken34
            • Apr 2026
            • 11
            Lmaoo good point. I’m sorry this is my first real project so I’m a little slow. Gonna cap off all the removed vacuum lines today. It seems to idle around 2000rpm now after removing the tps. I appreciate the pointers
