What Cams to buy??
  • Luis325
    • 3847
    What Cams to buy??
    I got a 327i with stock 325i cams and wanted to upgrade to a more aggresive cam but not shure which one to get.
    Would i need to upgrade the inyectors to 17lbs, i have the stock 14lbs....
    I saw the IE 272 new billet cam for $355 is this a good cam?
    Also saw Shrick makes some cams, 272, 288?
    Also for the cam swap do i need to upgrade the springs valves, etc?
    Would i need a perf chip? Or upgraded afm?
    I allready have a comforti chip but its not for cams....
    Thanks
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
  • SpecM
    • Oct 2005
    • 4531
    cams? you only need one, buddy!
    schnick 272 is good for the street
    1989 cirrisblau-metallic 325i
    • vr2jetta
      • 460
      If you are gonna do a cam you might as well do springs for the added insurance. You wouldnt want to spend all that money to just have spring failure. Do it right the first time. I know, I know, it sucks, more money, more time.
      • Luis325
        • 3847
        LOL thanks i new that...
        What springs are recomended or more used by members for the cam?
        • digger
          • Nov 2005
          • 6147
          use 284/272 schrick with new stock valve springs.......
          • Luis325
            • 3847
            OK what about the ECu? do i need a chip to tune for the cam?or bigger injectors?
            • vr2jetta
              • 460
              When you buy a cam it should specify if you need springs with more lift capability. If you are going to get a cam, call the manufacturer and see what they recommend upgrading with their product, that is what they are there for. They (should) do all sorts of R&D when they develop the cam and they should know what will perform best with it, especially if its schrick. If you install a cam, obviously you are adding more air to the motor, so upgrading the AFM or injectors probably wouldnt be a bad idea. The cam is the heart of the motor, and any upgrades further than that will compliment it, therefore producing more power.
              • Luis325
                • 3847
                Ok I found the schrick cams at $424 in turner motorsport.
                Which one would be best for a solo 1 or autocross car only,
                272, 284, 288 ?
                  • 34839
                  go with the 284/272. new OEM springs are fine for this cam - schrick reccomends upgraded springs when you go with their 288 or 304 however.
                  you'll want to put it on a dyno and see what it looks like after - more than likely it will need some tuning.
                  • Motorsports
                    • Feb 2007
                    • 2882
                    like mentioned above. If you doing a Cam swap definately buy a set of springs. It also depends on what you're looking for on a cam 284/272 is perfect for street use and some autocross. If you're not doing a ground up build on the engine and your not looking for big HP. Thats your best bet. Now If you are building a Racing engine and your looking for big HP numbers go with a more agressive cam like a 288 or a 304. but thats gonna give you a more rough idle, and a choppy feel to the engine.
                      • 34839
                      you can still make decent power with the 284/272 as well. over 200 at the crank with good tuning. :)
                      • SpecM
                        • Oct 2005
                        • 4531
                        what avenue are you using to tune, Nando?
                          • 34839
                          megasquirt. runs butter smooth right now. :)
                          • Luis325
                            • 3847
                            ok i guess ill go with the 284... Its a track only car,
                            but i want a car thats relliable. And can handle the abuse...LOL!!!!
                            • a_thomasmr23
                              • Nov 2008
                              • 152
                              a beehive style spring is a technology improvement over stock springs
                              bring it http://athomasmr23.mybrute.com
