What Cams to buy??
  • Luis325
    • 3847
    Still havent desided on what cam to buy...... PLEASE HELP Me!!!
    Since the 327i swap I added a comforti 7,000rpm chip and 17.5lbs injectors.
    Need help deciding what cam to buy....
    Its a track driven car only....But people say that the 288 will not clear the valves????
    would a 272 or a 284 help... The car needs more power up top.
    also have 2:96 gears dont know if I should go to 3:73 or 4:10.
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
    • digger
      • Nov 2005
      • 6182
      piston to valve clearance will be an issue with the 288, the 284/272 just scrapes in but needs to be checked prior to starting.
      catcam make some nice cams the 285/285 or 285/264 might be worth a shot.
      • Luis325
        • 3847
        I gues my best bet would be to just go ahead with a 272 cam with good springs and rockers and valves and a 3:73lsd... I gues it woul really help my car allot...
        • txtorquemade
          • 1758
          Megasquirt
          288 Shrick
          Upgrade springs
          New valve guides (titanium maybe)
          M30 ARM
          Headers
          Straight exhaust delete cat, with Remus muffler
          Heat shielded CAI
          Of course your going to do a new TB and tensioner. Maybe New cam gears. Stewart WP. Underdrive pulleys, delete AC if you havent already. PS too if its a track car only.
          sigpic 1987 325is
            • 34844
            titanium valve guides? lol
            • txtorquemade
              • 1758
              I saw them on e46 fanatics... LOL...
              Sounds good. Im pretty sure they are an alloy with titanium. Also didnt realize 288 cam would cause an issue. But, yeah.. can see how it would I guess.
              sigpic 1987 325is
              • weaksauce
                • Apr 2009
                • 550
                Originally posted by txtorquemade
                Megasquirt
                288 Shrick
                Upgrade springs
                M30 ARM
                Headers
                Heat shielded CAI
                titanium retainers maybe.....
                m30 AFM and megasquirt are a wierd combo, right. I thought with MS you could go MAP and get rid of the AFM.
                • Mitch M
                  • 881
                  Are u running ETA or SETA pistons? If u milled your head 0.020" like I did w/ ETA pistons, I'd check piston to valve clearance on even the 272. Stock "k" cam clearance on my engine is 0.065" intake...that's below the recommenced 0.080 i / 0.100 ex safe zone.
