2.7i help please
  • SpeedWiz
    • Jul 2009
    • 31
    2.7i help please
    Hi i have a 325e that i am currently making into a 327i
    so far i have changed:
    AFM, TPS, MANIFOLD, WIRING HARNESS, CPU, PULLEYS, SENSORS, ETC.
    (I kept my e injectors in with the fpr)
    I have an issue tho,
    my car fires up just fine and idles okay but if i touch the throtle a little bit it wants to die on me but if i press it a little more it will rev up but wont stay constant it bouces. I have checked the sensors, oxygen sensor AFM TPS they are all okay. It runs very rich and back fires some
    please if anyone can help please post thank you
  • Devil Inc
    • Jan 2008
    • 802
    You need to use the I injectors and FPR. That should solve most of your issue.
    • SpeedWiz
      • Jul 2009
      • 31
      why would that matter tho? because thge e injectors are smaller
      wouldnt the i larger injectors just make it more rich?
      • Devil Inc
        • Jan 2008
        • 802
        They're of different impendance. Also, the FPR is 2.5 bar on the ETA and 3.0 bar on the I engine.
        • SpeedWiz
          • Jul 2009
          • 31
          but more pressure would give it more fuel wouldn't it?
          its runnning rich i need less right?
          • Devil Inc
            • Jan 2008
            • 802
            The amount of fuel delivered to the combustion chamber is controled by the DME. Which uses readings from the: TPS, O2 sensor, AFM to determine and tailor the amount that gets sent. The FPR regulates the fuel pressure in the fuel rail, not the amount of fuel delivered to the cylinders.
            • Devil Inc
              • Jan 2008
              • 802
              The injectors are like middle men, they do what the computer tells them. In your case they are misinterpreting the signal and delivering the wrong amount of fuel.
              • slo325i
                • 417
                Stop running the car... You'll burn up the injector driver due to the impedence difference.
                '89 325i - Totaled... good bye my love...
                '87 327i budget stroker - SOLD!!!
                '92 240sx - ca18det powered drift toy - SOLD!!!
                '89 325i - coupe - NEW daily
                '96 Audi A6 Quattro- Grocery getter/baby hauler
                '99 Busa - weekend wheelie monster
                • SpeedWiz
                  • Jul 2009
                  • 31
                  ok but do you have any advice on how to fix the problem?
                  • Alkasquawlik
                    • 4557
                    Read. ^
                    SC*AR
                    Originally posted by JamesE30
                    And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
                      • 34839
                      you will fry that ECU if you don't change the injectors. It may already be too late. the reason is because e injectors are low resistance and i injectors are high resistance. the drivers in the i ECU are only designed to run high resistance injectors.
                      • Arems87e
                        • May 2008
                        • 102
                        Dude! just do as they say, Trust Me...i made tha same mistake while i was building mine. If you're going to use e injectors, u'll need to change the harness, ECU, and AFM back..I dont think tha FPR matters, cause i've run both FPRs b4
                          • 34839
                          the FPR absolutely does matter, because the e uses a lower fuel pressure (2.5 bar vs 3 bar). But using the wrong FPR isn't as big of a deal as using the wrong injectors
                          • SpeedWiz
                            • Jul 2009
                            • 31
                            thank you guys so much! it works!
                            next is a 325i head :-]
                            oh by the way sorry for the post asking about how to fix that was my girlfriend replying
                            sorry guys and thanks
                            • eta
                              • 63
                              eta injectors flow more than i injectors! So thats why a higher FPR is needed. It works well I have done it as well.
