headgasket complete: car wont run
  • formula driver
    • 2263
    I just finished doin a head gasket on my m20b25, everything is put back together and the car wont run.
    Car starts up and than the revs jump and the car dies. You can keep the car alive with a little throttle.
    Im thinking it could be a fuel problem or maybe a vacumm leak, maybe even a tps. I swapped the ICV, but no luck.
    Do you guys have any suggestions on what to check? Thanks...
    Make sure that the TPS is connected and that the idle switch closes when the throttle stop is .020-.060" off the stop screw. Hearing the click isn't sufficient, you jave to check the switch with an ohmmeter or test light.
    If not the TPS, the problem is most likely to be an intake leak.
    • quickervicar
      • 1197
      Are you absolutely, positively sure that the t-belt didn't jump a tooth? Mine was tough starting & required a bit of throttle to keep running. I re-timed it, but the damage was already done (bent valve).
      • formula driver
        • 2263
        Im not 100 % sure, no. I guess thats something to check.
        • quickervicar
          • 1197
          With the hood on it's kind of hard to see if the top marks line up. Double-check it, just to be sure. If you don't hear any nasty tapping you might be alright.
          • formula driver
            • 2263
            Im hoping to god ths is not the problem...
            Im definatly checking the timing first...
            • formula driver
              • 2263
              any other tips folks?
              • quickervicar
                • 1197
                All switches, sensors, etc. are confirmed to be hooked up after the HG job? Just checking over the obvious...
                • twright
                  • 707
                  Bad vacuum leak. Make sure all of the hoses are connected.
                  • formula driver
                    • 2263
                    You sure? you sound sure...
                    lol
                    Thanks guys...
                    Im gonna take the intake side back apart and check everything.
                    • quickervicar
                      • 1197
                      Don't forget the little hidden port on the bottom side of the throttle body. (terminates in the charcoal canister)
                        • 34839
                        did you plug the crank sensor and inductive sensors into the wrong ends? they have similar plugs right next to each other that you can get in backwards and it won't run that way (no crank signal = no fuel or spark).
                          • 34839
                          does the ICV buzz with the ignition on?
                          • formula driver
                            • 2263
                            Im pretty sure its good, but ill check it as well.
                            • formula driver
                              • 2263
                              dont think so but its definatly on the check list.
