M42 radiator fitment
    • 34839
    #31
    Originally posted by SpecM
    yes, but what about the smaller, two-groove pully that sits at the very end?
    you're talking with no PS? I guess not then.
    • Naplm00
      • Nov 2008
      • 1573
      #32
      yea, without PS...i have a manua rack that im puttin on.
      I didnt know if that smaller 2 groove was needed...someone a long while ago said that you could not remove it..no idea why
      88 325ic ~~~> Rusty and ugly
      85 E ~~~> RIP
      • SpecM
        • Oct 2005
        • 4531
        #33
        I suppose you would need to get shorter bolts, thats about it...
        1989 cirrisblau-metallic 325i
          • 34839
          #34
          the pulley is like 2mm thick, I don't think you'd ahve a problem using regular bolts, or none at all since you're not using it.
          • SpecM
            • Oct 2005
            • 4531
            #35
            you'd still need to attach the wp/alt pully and toothed wheel to the crank hub, right? don't the six bolts do that too?
            • NC325iC
              • Mar 2004
              • 6565
              #36
              they do, you would still need bolts, nando just wasnt thinking straight... right nando.
              im interested in this also, Matt is there a specific reason why you would need the newer style WP? it seems that just running a hose from the 2nd output of the old WP to the res would be easier than chopping a $55 T hose.
                • 34839
                #37
                I was thinking the pulley for the water pump/alternator is part of the damper/crank wheel. Unless it's for the PS.
                • NC325iC
                  • Mar 2004
                  • 6565
                  #38
                  it is, and the ps/ac pulley goes in the center of it as a seperate piece. but they use the same bolts
                    • 34839
                    #39
                    right, those bolts hold on the crank wheel. that's why you need them.. lol.
                    • Naplm00
                      • Nov 2008
                      • 1573
                      #40
                      lol ok
                      85 E ~~~> RIP
                      • Naplm00
                        • Nov 2008
                        • 1573
                        #41
                        an update: bought the radiator, new sensor, thermostat and gaskets to do this job
                        It will be part of a overall huge job of oilpan gasket, swapping steering racks and replacing intake gaskets
                        85 E ~~~> RIP
