19# injectors, would these work?
  • Sagaris
    • Sep 2009
    • 2243
    or in other words
    Is a 19# fuel injector a 19# fuel injector? or do I need to watch out for different nozzles, plug connectors and brands?
  • 2.5-12
    • Jan 2010
    • 1814
    those work.
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
    • Sagaris
      • Sep 2009
      • 2243
      I called Mark D and he convinced me to go with 17# injectors. He said that part of the reason he made the chip for the 19# is because that is the size the Mustang uses which should make them more available /cheaper. Looks like im going to be looking for some 17#ers thanks for the confirmation though
      • 2.5-12
        • Jan 2010
        • 1814
        alrighty, the ECM re calibrates just perfect with the ford 19# injectors though ;)
        • AlarmedBread
          • Sep 2006
          • 1510
          WRONG, post a dyno sheet with AFR please. ;) Stock ecu will run about 10.5 AFR with 19lb injectors.
          • LowR3V'in
            • 4209
            but but but but the ecu will make it perfect. j/k
              • 37828
              17, a much better choice.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • 2.5-12
                • Jan 2010
                • 1814
                fair enough - I guess I just assumed it was calibrated since I run the 19lb injectors and they seem fine,
                still learning about the M20 every day
                • Tree_e30
                  • 43
                  dont waste your money unless you get a fuel pressure reg the maf doesnt adjust to the large amont of fuel the bads are 1 the engine light stays on 2 car runs to rich and 3 the car losses power low end i hear alot of buzz about these but honestly my car felt better with 13lb
                  :puppy:text me anytime #3233312676# aim:gtrr34gskyline:aim myspace.com/gtrr34gskyline add me
                  • kamotors
                    • Nov 2007
                    • 7102
                    7speedshop.com
                    • TrentW
                      • 2815
                      Part # for the 17lb injectors?
                      • Sagaris
                        • Sep 2009
                        • 2243
                        RealOEM has 13641730060 for a part# on M50 injectors off a '95 E34. I would look at my own injectors which are on the car, but a giant aluminum crab is guarding them :(
                          • 34839
                          you don't have to remove anything but the injector harness and fuel rail to get at the injectors. taking the valve cover out of the way helps though.
                          • rvaughnp
                            • 136
                            Do these have the 4 pintle design? The realoem ones. I found them but just curious.
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              No they would be single pintle design II and that is the BMW part number. It is virtually meaningless to anybody but the dealership's part system or a vendor that uses the BMW system. The bosch number for a design III (newer with a better spray pattern and four pintle tip)
                              Like these:
                              Witchhunter.com has info on most fuel injectors available:
                              An M50 runs at 3.5 BAR fuel pressure where as an M20 only runs 3.0 BAR so an injector that flows 17.5 lb/hr at 3.5 BAR will only flow 16.2 lb/hr at 3.0 BAR keep that in mind.
                              '89 Alpine S52 with goodies
