B27/B25 Cylinder head components
  • Mitch M
    • 881
    Originally posted by rcfanatic
    Can you elaborate more? I probably won't spend too much time above 6k rpm aside from fractions of a second when I'm winding her out, which isn't that often.
    On related note the machine shop put .030" shims in the valve springs to stiffen them a little. *just out of curiosity* Would this allow me to safely run above 7k rpm? (assume rev limiter disabled)
    I "think" I read that in one of the Pete McHenry Roundel M20 articles. May want to ask Stu. BMW would not change a part design if they didn't think it was necessary.
    The stock valvetrain seems to be fine to the 6900 rpm limit of most chips other than the occasional broken rocker arm. A 0.030" shim isn't going to change the open and closed rates very much but you could crunch he numbers if you wanted to know the exact change.
    • rcfanatic
      • 490
      Well then I guess to be on the safe side:
      Does anyone have a late model cam sprocket they wouldn't mind parting with?
        • 34839
        don't use the stamped-steel cam gear. get the cast one. The stamped ones are a failure point. there's a TSB on it too.
        I have an extra I could sell.
