Need some help on 885 head
  • moe30
    • Jun 2010
    • 721
    So I'm picking up a 87 325es tomorrow... and I have already head how these can be a bit sluggish. So now I'm wanting to research putting an 885 head on my "e" block. (If I'm wrong on anything please correct me, I'm still learning)
    So this is the list of what I'll need from a 325i
    dme
    harness
    injectors
    fuel pressure regulator
    head
    afm
    throttle body
    radiator
    *intake manifold
    *airbox
    (Thanks Kershaw)
    *Toothed harmonic balancer, CPS, & bracket (Thanks jlevie)
    Also do I have do to any modifications to the eta block? I'm really hoping this is something I can just bolt right up. Any info or opinions will be greatly appeciated.
  • Kershaw
    • 11822
    intake manifold
    airbox
    AWD > RWD
      Toothed harmonic balancer, CPS, & bracket.
      You won't need a different radiator.
      • moe30
        • Jun 2010
        • 721
        Well I was told that it was recommended... not needed.
        It sounds like I need everything but the block off a 2.5 lol
          • 34839
          an 885 head swap without the associated electronics is going to be pretty pointless.
          • moe30
            • Jun 2010
            • 721
            What electronics are needed? I was reading the trannies are the same in all and also mine is an es so it will have lsd
